82 FXR Won't turn over
Old 12-20-2014, 05:42 PM
nash615's Avatar
nash615
nash615 is offline
6th Gear
Default 82 FXR Won't turn over
Hoping you guys can help direct me with this. So far I've just been chasing a rabbit. ok...Hit starter and hear slow grinding noise...engine tries to turn over but won't. Check battery (new) and showing 12. Check starter, it was dragging. Replace both starter and solenoid. Still won't turn over...just drags as though battery is about to give out. Thought that maybe it's the switch. Tried jumping from the starter to the solenoid. Nothing. What have I overlooked or what am I doing wrong? I would appreciate the help. Thanks.
Old 12-20-2014, 06:04 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is online now
Received 4,556 Likes on 2,883 Posts
you said you replaced the starter and the soleniod -- they were New or used ?????
did you remove all the battery connections and checked the ends for loosness as the wire may have overheated and un done its self ?????-- did you check the batterys chassis ground UNDER the bike it has a ground strap the goes from the frame to one of the lower bolts in the inner primary -- < THIS ---
Old 12-20-2014, 06:19 PM
nash615's Avatar
nash615
nash615 is offline
6th Gear
yes, new battery, starter and solenoid. I have performed and checked all that you mentioned.
Old 12-20-2014, 06:32 PM
johnjzjz's Avatar
johnjzjz
explain this < nothing ?????? whats nothing
Old 12-20-2014, 06:44 PM
nash615's Avatar
nash615
nash615 is offline
6th Gear
Crossing from starter to small post on solenoid...no spark, no spin from starter, no anything.
Old 12-20-2014, 06:48 PM
nash615's Avatar
nash615
nash615 is offline
6th Gear
Attempting to start the bike as you normally would when hitting the starter button you can hear the starter motor spin. Let off starter switch and try again. Only a drag sound and headlight dims.
Old 12-20-2014, 07:00 PM
johnjzjz's Avatar
johnjzjz
does your bike have a ford car type relay that is connected between the battery and the soleniod ????
if not your main battery cable or the ground is not staying connected to full battery voltage OR the battery has a grounded plate and shows 12 volts but under load is craps out - did you have the battery load tested like a autozone ?????
Old 12-20-2014, 07:45 PM
nash615's Avatar
nash615
nash615 is offline
6th Gear
No. Bought 2 weeks ago at HD.
Old 12-20-2014, 07:59 PM
johnjzjz's Avatar
johnjzjz
i own a shop at least 10 batterys a year we install out of the box are garbage today
matt_m_72
04-08-2019 08:47 PM
dannybam
Electrical/Lighting/Alarm
25
08-15-2018 08:20 AM
Badluckbikes
EVO
13
11-04-2016 11:54 AM
nash615
Shovelhead
12-21-2014 01:53 PM
irydasteelhorse
EVO
02-22-2014 10:00 PM
Quick Reply: 82 FXR Won't turn over
