hammering
Old Aug 7, 2015 | 01:44 PM
RandallJ's Avatar
RandallJ
Sorry to hear... take some pics... like to see myself..
Old Aug 7, 2015 | 02:50 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Piston that is smeared/stuck, or the crank is locked up tighter than a drum.
Scott
Old Aug 7, 2015 | 03:08 PM
RandallJ's Avatar
RandallJ
drag, at least you got it home I guess..
outside my world of "been there done that" stuff.. at least you got a world of help here ..
Old Aug 7, 2015 | 03:44 PM
berndog's Avatar
berndog
yeah ,well Ive been wrenching on this bike a few years now,and in all honesty ive learned more about wrenching my bike here than anywhere else,,and im very grateful I got it home ,last ride was Mothers Day ,surprise trip to my Moms 330k away for a surprise lunch,up the beautiful sunshine coast,,I made the trip all the way there all the way back to 3 km from home,,was a grateful ride,,,since then i bought a 2015 roadglide,and the ****in thing is leaking oil at 700km,,,and tech has the ***** to tell me at first service,that theres no leak,that its just messy from me not cleaning oil off after change,guess he assumes im just another rub!! cant wait to shake his hand after he sees the oil all down one side.
I tell ya I'd rather wrench on my shovel.
Old Aug 7, 2015 | 08:53 PM
TwiZted Biker's Avatar
TwiZted Biker
Have you popped the plugs and taken a look in the holes ? While pistons can seize it usually takes a hell of a beating at high RPM's to do it and then other things go whack loudly......
Pull the pushrod covers and see if anything looks fubar as it sounds like it may have sucked a valve and locked in the top of the piston , kinda what I'm hearing here , good luck man
Old Aug 7, 2015 | 10:41 PM
berndog's Avatar
berndog
Thats what I'm thinking too Twizted,,wanted to do a teardown anyways as all the gaskets leak, in top end,,even though rebuilt 3 years ago,,Ill let ya know what I find
Old Aug 8, 2015 | 09:18 AM
Racepres's Avatar
Racepres
Have never...ever locked a motor via bottom end nor piston seizure.
Something is going on mechanically...Betting there is a Pushrod that will fall out when the tube is removed...Dropped a Valve as that Twizted "horn dog" indicates...
Spinnin the **** out of an old Shovel can result in such happenings.
Old Aug 8, 2015 | 12:26 PM
TwiZted Biker
Nope, rods have a habit of making holes in case when they let go although I have seen a piston stick and the rod yank the lower half off, that made a mess. While I haven't seized one that wasn't ***** out racing I've seen the results of a few that did and what the damage told me didn't jive with what the owners was trying to sell.
Old Aug 10, 2015 | 05:21 AM
Hillsidecycle.com
Sponsor
All pie-in-the-sky guessing, until it is laid out on the workbench.
That usually solves the puzzle.
Scott
Old Aug 10, 2015 | 12:44 PM
guitarman023's Avatar
guitarman023
might pull the primary and wrench the motor backwards a little bit, if the valve made contact with the piston, you should probably tear into it anyways though
RSDUDA
Shovelhead
Sep 9, 2014 03:59 PM
En3may
Shovelhead
Apr 28, 2013 05:47 PM
ralv2rd53
Shovelhead
11
Apr 1, 2012 04:38 PM
Joe's FLH
Welcome Area Only
Aug 22, 2011 08:45 PM
Reffixer
Exhaust System Topics
Jan 10, 2006 01:22 PM
