Just got a 74 FXE
Old Oct 9, 2015 | 09:27 AM
Magnut1's Avatar
Magnut1
Mine shifts on the left and has 1 up and 3 down. With the drag bars, I can't mount the passenger pegs to the right side due to interference with the pipes.
Old Oct 23, 2015 | 08:38 AM
Magnut1's Avatar
Magnut1
finally figured out how to post pics again
Old Oct 23, 2015 | 09:42 AM
Racepres's Avatar
Racepres
The '70's FX came with that shift pattern...hold over from the original with a turned around floorboard setup onto the SuperGlide.
I can't see where the rear pipe is interfering with the Swingarm mount for the passenger pegs.
Old Oct 23, 2015 | 12:56 PM
Magnut1's Avatar
Magnut1
These drag pipes seem to sit a little higher than the stock ones would. If you sit on the bike it compresses the shock and sinks the swingarm further below the top of the pipe.
Old Oct 23, 2015 | 02:03 PM
Racepres's Avatar
Racepres
??? Really got me confused now....Should move the swingarm further above the pipes...does on mine!!!
Old Oct 23, 2015 | 02:26 PM
TwiZted Biker's Avatar
TwiZted Biker
Those pipes are sitting sweet , leave them alone whatever you do.
Old Oct 23, 2015 | 03:01 PM
Racepres's Avatar
Racepres
Agreed...they are straight and proper...I was Not suggesting moving the pipes....
Old Oct 23, 2015 | 03:25 PM
Magnut1's Avatar
Magnut1
Racepres you are right.. I don't know what I was thinking. It would push the frame down when you sit on it. Might have to revisit this position. I am taking it apart for the winter, just the tins and going to run the wiring (it has new wire harness and the prev owner just tucked the rest under the seat) and going to paint the tins, add the turn signals, get a new fuel shutoff valve, and either rebuild the "B" carb or maybe install a 78 FL carb and air cleaner I got with the deal. I think the fuel shutoff valve is not shutting all the way off. Also there is oil leaking around the top ridge of the oil tank. I will try to remember to get a picture. Not sure where it is coming from yet. Gonna take it for a ride this weekend before I put it up on the stand.
Old Oct 30, 2015 | 03:27 PM
Magnut1's Avatar
Magnut1
If anyone is interested in buying this asking $4800 or possible trade for 65-71 GTO pm me if interested.
Old Oct 30, 2015 | 03:47 PM
Super Glidester's Avatar
Super Glidester
I wouldn't mind an FX or FXE, just to have.
