67 shovel shifting problems
Old 04-07-2016, 11:52 PM
5hands5's Avatar
5hands5
5hands5 is offline
Default 67 shovel shifting problems
I took off the primary and removed the clutch plates, cleaned them, then put them back on. The problem is now when I shift, the pin holding the shifter in place snaps. It never used to do this before. I tighten the bolts on the shifter as tight as I can but the pin keeps snapping. Any hints?
Old 04-08-2016, 07:39 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,564 Likes on 2,889 Posts
the bolts are too long and its right at this time is desired to slide back and forth - add some washers to teach of the 3 bolts
Old 04-09-2016, 12:52 AM
5hands5's Avatar
5hands5
5hands5 is offline
Default 67 shifting problem
I was not very clear. It is my foot shifter that is causing the problem. There is a bolt that tightens it down and a pin that keeps it in place. The peg coming out of the primary is smooth so the bolt tightens the foot shifter and the pin keeps the foot shifter in place. The pin keeps snapping and it never used to.
Old-Evo
EVO
22
10-20-2023 11:49 AM
jamess71
07-15-2016 10:08 AM
ro9beam2002
07-03-2012 08:00 PM
speedkills
03-02-2010 08:20 PM
89FLHT
05-23-2006 03:05 PM
Quick Reply: 67 shovel shifting problems
