shovelhead noise!!
Old May 26, 2008 | 09:44 AM
jmetro's Avatar
jmetro
Default RE: shovelhead noise!!
ummmm.... it sounds like the problem might be easier than all this. have you filled your gas tanks since you started riding?? 200 some odd miles sounds like about a tanks worth of riding. the top end sounds tend to echo in empty gas tanks, my engine sounds noisy as hell when my gas is almost empty, but when full, nice and somewhat quiet.
Old Jul 29, 2008 | 11:04 PM
mjvandal's Avatar
mjvandal
jmetro has a point.&nbsp\\; You dont notice it if you run with a 3 gallon tank but you do with a 5 gallon.&nbsp\\; When my tank get down to a quarter&nbsp\\;gas left&nbsp\\;I hear lots of nosies I cant when the tanks full.
Old Jul 29, 2008 | 11:06 PM
mjvandal's Avatar
mjvandal
Good God.&nbsp\\; I should check the dates of these posts before I respond.&nbsp\\; LOL
Old Jul 30, 2008 | 07:39 AM
swatsonv92's Avatar
swatsonv92
6th Gear
mj vandal, responding to a post later on is cool. usable info is good, if not to the original guy, then to someone else looking later on
Old Jul 30, 2008 | 10:15 AM
powdercoater's Avatar
powdercoater
May also be timing knock.&nbsp\\; If you did top off your tank with a low octane gas your shovel will tell you not to do that.&nbsp\\; &nbsp\\; Even if you used the good stuff, your timing plate could have loosened a little so your timing is too far advanced.&nbsp\\; Something to check anyway.
retmar
Jul 10, 2015 05:34 PM
Lyonsboy07
Shovelhead
Oct 26, 2013 08:05 PM
rhyno95
EVO
24
May 14, 2013 09:56 AM
Go Shovelhead Go
Shovelhead
Nov 3, 2011 09:34 AM
testifer
May 24, 2010 01:18 AM
