79 FLH-80 Compression and Timing Questions
I recently got the bike running after fixing starter system and installing new Dyna S ignition. I set the timing statically with a test light. I bought the long clear timing plug and I'm still not able to see the the mark with my inductive timing light.
I'm running an older S&S Super E that I removed, cleaned, and added a rebuild kit.
After letting the bike warm up for a few minutes, I noticed the exhaust was hotter coming out of the front cylinder exhaust pipe vs the rear. I hit both pipes with my temp gun and the front was considerably hotter than the rear. Both plugs are getting spark and I did a compression test 100 psi front and 95 psi in the back (without WOT - I forgot).
Rear plug looks too clean. Could the rear cylinder be getting too much fuel? Maybe timing is still off?
Thoughts and input please.
Thanks!
now i dont know what you actually did to confirm the front is hotter but the front is hotter as the flywheels are sending oil directly up the rear cylinder, and not as much in the front by the 45 degrees design - look at the engine and think about the wheels turning counterclockwise from the left side
The bike and working on shovels is new to me so I don't have a real reference point for how they run. I used an I/R thermometer and pointed it at the pipe near the cylinder head. There was around 100 degree difference.
I'll look at the timing again, check for intake leaks when its running, and try the 295/70 jets you mentioned in my other post.
But also keep in mind you are running an air cooled motorcycle in a stationary position. I would set up a fan in front of the bike to help regulate temps and try to have better real world conditions.
Last, intake leaks can cause lots of problems, check that out.
