Stator assembly question
Old May 5, 2017 | 11:21 AM
adm's Avatar
adm
Default Stator assembly question
So....I am going to put the stator cover (rotor) on and then the inner primary.
But a question first. In the bag of bits from when I took the rotor off, I have the magnetic rotor itself, the old o-ring rubber gasket that goes on the crankcase and a thinnish (0.060") large diameter thrust washer.
I have a new gasket, but does the thrust washer go between the stator and the rotor or does it go on the outside on the rotor before the compensating sprocket?
I think the answer is between the rotor and the stator - that is the most logical answer as I took the comp sprocket assembly off separately and bagged it up separately - so if the washer was on the outside of the rotor, it should be in that bag - but thought it was worth a check.
It doesn't appear show up in the parts book or get mentioned in the manual though...
Old May 6, 2017 | 06:52 AM
johnjzjz's Avatar
johnjzjz
its in the parts pictures - normally we look at the mating surfaces you should see it goes between the sprocket shaft spacer and the rotor to space the rotor out just a bit
Old May 6, 2017 | 01:55 PM
adm's Avatar
adm
Thanks John - that's what I thought. And what I did.
Panthers65
EVO
Aug 8, 2016 02:52 PM
Yankee Dog
EVO
Jul 4, 2015 02:21 PM
Pinetop
EVO
Apr 28, 2014 08:10 AM
wiseguyups
Aug 30, 2009 07:40 PM
slickfit
General Topics/Tech Tips
Jan 1, 2008 02:49 PM
