how do I unclog oil passage in front rocker box/
Old Nov 10, 2017 | 02:21 PM
rawger's Avatar
rawger
Default how do I unclog oil passage in front rocker box/
1977 FXE garage find. 3500 orig miles. I've replaced hoses,, seals. flushed and replaced fluids. front rocker box does not seem to be oiling. when I disconnect oil line from front to rear rockerbox, rear pumps out lots of oil. if I try to manually pump oil or air in to front, it just builds pressure.
Been riding since 68, 13th bike, 1st shovel. Do most of my own wrenching, but not a mechanic. I do have 1970-1977 factory service manual..
Any and all help and/or tips greatly appreciated.
Thank You
Rawg
Old Nov 10, 2017 | 05:00 PM
johnjzjz's Avatar
johnjzjz
the end play in the front rocker boxes rocker arm is probably on the tight side
air pressure verses hydraulic pressure is 2 different things plus your blowing air against oil in the escape location and its cold
you did not say this was the engines first start up or even why you are looking for something that might not be broken
Old Nov 12, 2017 | 01:03 PM
rawger's Avatar
rawger
Not first start up. rebuilt carb, changed fuel hoses and some oil lines. Have started it at least 20 times. changed oil twice so far. gradually tuning, starts 1st or 2nd kick most of the time. front cylinder running hot. replaced intake seals, that helped. Replaced tappet screen. plumbed up oil pressure gauge at tappet screen plug. 40lbs at start up, drops to 20 then 5 at warm idle. removed oil line between front and rear rocker boxes. old dirty oil only on the front fitting. when I kick it with line removed plenty fresh clean oil from rear rocker. next I'll try to plumb up a clear hose between rockers to see if there is flow.
Old Nov 12, 2017 | 01:13 PM
TwiZted Biker's Avatar
TwiZted Biker
Crack open the front exhaust big rocker shaft end plug kicking it over or at an idle, you get oil you know the rear head is passing it through without all the goofy pluming. This will narrow down the issues to end play too tight as John said or bushing galled to the shafts blocking the pin hole ports. I have seen guys block the ends of the fitting with too much thread tape before so beware.
Meatpants
Engine Mechanical Topics
Sep 30, 2018 10:02 AM
Herbg
Sep 23, 2012 09:10 PM
bigjake99
Ironhead
Aug 9, 2009 11:48 AM
WIZARD
Exhaust System Topics
Jan 17, 2009 10:55 AM
gilb
Panhead
Aug 10, 2007 10:05 PM
