Stocking up the Toolbox...
Old Apr 8, 2018 | 12:45 PM
coax9952's Avatar
coax9952
Default Stocking up the Toolbox...
Okay, Here's a Poll for Y'all.....
Other than the normal hand tools and general doodads we keep around for Maintenance, What, in everyone's learned opinion, are the must-have HD Specific Tools that the discerning Shovelhead owner needs to start collecting. that will get semi-regular use, you know... Clutch pullers and Special nut driver sockets stuff. What say you all.......
Old Apr 8, 2018 | 03:39 PM
Tat2d's Avatar
Tat2d
The special tools I use most in routine work are:
Clutch hub puller
1-1/2" socket for compensator
Curved 9/16" wrench for head bolts
9/16" tourqe adapter for head bolts
Tappet block alignment tool
Spanner wrench for neck nut
Safety wire pliers
Snap ring pliers
Chain breaker
This is assuming you have a well stocked mechanics set already along with drills, taps, cutting & grinding equipment etc.
I'm sure there are quite a few others that either I'm forgetting about or that others use regularly. Sometimes you just have to be creative and make something that will work or improvise (the reason I have a screwdriver handle covered in clutch hub teeth marks :-)
Add to that list a connector pin and socket extrating tool and crimpers for repairing/replacing wire and connector bodies.
Old Apr 8, 2018 | 05:09 PM
Racepres's Avatar
Racepres
Leatherman... if I need more... That's why god made Cell Phones!!!
Old Apr 8, 2018 | 05:25 PM
brntkndll's Avatar
brntkndll
Transmission sprocket nut socket. Don't forget....reverse threads.
Old Apr 8, 2018 | 05:57 PM
Tat2d's Avatar
Tat2d
Now a days on the road ^^^^ and not much else since a tool or truck is a call away. Gotta say that is nice.
Back in the day even drag pipes didn't drown out the sound of all the tools bouncing around in fork bags!
Old Apr 8, 2018 | 05:58 PM
JAMES2's Avatar
JAMES2
Bailing wire, Vice grip, paper matches, duct tape and fire extinguisher...
Old Apr 8, 2018 | 06:18 PM
old mago's Avatar
old mago
rattle gun and some form of bike lift
Old Apr 8, 2018 | 07:40 PM
TwiZted Biker's Avatar
TwiZted Biker
Tranny sprocket nut tool, #1 specialty item for an old bike mechanic besides the clutch hub puller, the rest has been covered.
Old Apr 8, 2018 | 10:32 PM
Hurricane 68's Avatar
Hurricane 68
At least one of every thing else and possable two of those other things
Wild Bill
Old Apr 8, 2018 | 11:16 PM
coax9952's Avatar
coax9952
Yeah, I'm a Bit of a Tool Hoarder, In my Circle, I'm famous for having 5 of every tool known to man. What can I say, it's a sickness.... But I will not pay JIMS Tools prices for a bent nipple shiny thingy if i'm only gonna use it once.....Thanks for the list, I figure the thread will help the next nooby.
