Tire pressure recommendation
Old May 21, 2018 | 08:31 AM
Architect's Avatar
Architect
Originally Posted by AJSHOVEL
If you run tire pressures recommended in a 1970's manual you will be severely under pressured and could be dangerous. Old school rule of thumb is look at the Max PSI on tire and subtract 10% as a good starting point.
I just had an issue with my Shinko tires on the '70. Manual pressure was in the low 20's, I called Shinko they said go with the max pressure listed on the sidewall, 41 PSI. They offered that some people take out a pound or two for comfort, so I am now running about 38 PSI.
Moral of my story, call your tire manufacturer.
Old May 21, 2018 | 09:37 AM
Wm435's Avatar
Wm435
Thats a great advice and I tried to call and I automatically get a voicemail for the mortocyle department.. I have Dunlop tires here is the number
8008458378
Old May 21, 2018 | 11:17 AM
Wm435's Avatar
Wm435
I called a guy name Dave at Dunlop tires and he said 36 front and 36 rear. Which equals to minus 10% of maximum tire pressure coincidentally. He also said that you shouldn't go off the old school manuals only because tire technology has changed dramatically and going off the old recommendation isn't a good idea with new tires from this era
Old Oct 25, 2019 | 10:00 PM
danzio's Avatar
danzio
I remember my little brother insisted once, if cars have carburetors then motorcycles must have motorburetors.
No matter how hard I tried, I could not convince him otherwise.
But he was only 8 years old at the time.
That's all I have.
Old Nov 2, 2019 | 01:16 PM
hdbob2006's Avatar
hdbob2006
Originally Posted by Wm435
I was looking in my original owners manual for my 1979 shovelhead flh classic and the recomendere PSI at maximum is 32 PSI; however, I looked on my tire and it said 40 PSI max recommend. Which tire pressure should I follow? I had my tires at 38.5 PSI and rode nice, now I have 40.5 PSI and it feels "a little tippy" so I'm back to 38.5 PSI. The tire size is original to the bike
I just sold my 1980-83 factory service manual,and for the FL it showed 36 front 40 rear. I had it written on the front cover.
Old Nov 4, 2019 | 09:05 AM
rockher_man's Avatar
rockher_man
Default Tire pressure.....😶
When I found my 1979 Electra Glide 1200 FLH King of the Highway all she needed
was new tires.
Metzler Ultra Marathon Wide White Walls.....👍
Sidewall shows 50-PSI max. I'm running about 45-47 rear and about 43-PSI front.
She runs like she's on rails! I can lean this big heavyweight (765 lb. wet) and scrape
my floor boards easy. Lean more at speed.
I recommend these Metzler to everyone on an FLH!
Old Nov 4, 2019 | 09:22 AM
Bass Player's Avatar
Bass Player
My 81 FLT is run at 38 front , 40 rear. Anything less and the bike wants to wallow around. You will know if it's too low, bike won't handle worth a crap.
Old Dec 31, 2019 | 10:54 PM
scooter1128's Avatar
scooter1128
bass, what tires you running on your flt? curious since I have an 80 flt? mine has the "old school" looking tires on it but I'd like to change them to a modern tire.
Old Jan 1, 2020 | 03:01 AM
mr.precision's Avatar
mr.precision
That's it exactly.
Every bagger I have owned.... shovels, evos, twin cams..... will wallow around if the tire pressure is too low or mismatched from front to back. I run 34/34 in my 1982 FLHC and 38/40 in my evo bagger. It's amazing how much difference it makes.
Old Oct 19, 2021 | 05:50 AM
TriDan's Avatar
TriDan
Be careful, if you have too much pressure, you'll bend your Oprod.
Atlaska
Jul 9, 2025 06:58 PM
WVDevil
Wheels/Tires
May 19, 2015 09:59 AM
mxz600
Apr 14, 2009 08:26 PM
morjubet
Jan 27, 2009 07:33 PM
pyro
Ironhead
13
Nov 20, 2006 01:12 PM
