Trans question
Old Aug 11, 2018 | 09:57 PM
mplecha's Avatar
mplecha
Default Trans question
I have a 78 flh with a leaky transmission. I have a second transmission from an earlier bike (72 I believe). My 78 does not have the L key on the main shaft spacer but the earlier one does. Are these two spacers interchangeable? Which style is preferred?
Old Aug 12, 2018 | 07:16 AM
johnjzjz's Avatar
johnjzjz
the late is a caged hi gear bearing and the spacer is for that app - the 72 is a loose roller bearing and the spacer is for that = now the cut out is a throw back to the days before they had a seal in hi gear and the clip can be omitted but they don't interchange the two units
but you can swap out the complete unit one for the other
Old Aug 12, 2018 | 11:14 AM
mplecha's Avatar
mplecha
Thank you. That is exactly the info I was looking for.
Old Aug 24, 2018 | 01:35 AM
mplecha's Avatar
mplecha
I have another question about the transmission. I was looking at the early 78 parts manual and noticed the cork seal behind the mainsheet spacer is listed as 41 to early 77. Does that mean the 78 should not have a cork seal between the case and spacer?
Old Aug 24, 2018 | 06:42 AM
johnjzjz's Avatar
johnjzjz
2 seals were used through the years
original early seal with the cork backing, is a single lip type and the rear of the seal is open for the cork to have a location, so it does not become flattened when installed with the seal - but the later that is double lip style seal, the back of the seal is closed leaving no room for the cork
the seal spacer still has in some transition years, the small clip for the spacer / hi gear cog against the drive gear - leave it out as well using the double lip type as well as the cork - and yes the double is a better seal design -- but hi gear bushing and OR the mainshaft area under the bushing is suspect in any leak - original bushing material is tougher then the steel on the shaft and over time the shaft wears away - this leaves you with never being able to install a standard size bushing as its too loose at the beginning of its install
its 50/50 to re use the mainshaft and or hi gear its self - everything is today --- the newest 4 speed it over 30 years ago - but sometimes you can just re bush the hi gear and re use everything else - never happens with a bike I own or when I don't have the parts in stock
Old Aug 24, 2018 | 03:10 PM
mplecha's Avatar
mplecha
I've been using the cork behind the spacer in my transmission. is it possible that could cause the trans to leak?
Old Aug 24, 2018 | 05:25 PM
johnjzjz's Avatar
johnjzjz
did you read what I wrote - what seal did you use will answer your question
Old Aug 24, 2018 | 05:45 PM
mplecha's Avatar
mplecha
I've been using Jims double lip seals. I'll try to reseal it again this weekend.
Old Aug 24, 2018 | 05:50 PM
johnjzjz's Avatar
johnjzjz
the cork is a pancake when you remove - it and the thickness of a double cant catch the out side lip of the second part of the seal correctly - but still think you have wear issues but then again always a hope it works going on with a shovel
Old Aug 24, 2018 | 05:59 PM
mplecha's Avatar
mplecha
I'm not sure I follow. What do you mean by the second part of the seal?
The issue I've been having is the oil leaks with the bike on the stand constantly. its not a fast leak, but it doesn't stop until the oil level gets below the seal in the case. I've tried changing the seal and spacer a few times with the same results. I figured I'd give it another shot, before I give it to someone else.
