71 engine shaft
Old Nov 7, 2018 | 05:29 PM
badfl97's Avatar
badfl97
Default 71 engine shaft
I am going to put an open primary on my 71 FXE kick only does anyone know if engine shaft is splined or tapered, I know transmission is tapered??
thanks
Old Nov 7, 2018 | 05:30 PM
johnjzjz's Avatar
johnjzjz
splined for sure if it what you say it is
Old Nov 7, 2018 | 05:33 PM
badfl97's Avatar
badfl97
Thanks yes it’s a 71 engine and transmission
Old Nov 7, 2018 | 05:34 PM
johnjzjz's Avatar
johnjzjz
your good to go
Old Nov 7, 2018 | 05:37 PM
badfl97's Avatar
badfl97
Do you know anything about open primary systems would you go with primo or BDL?
Old Nov 7, 2018 | 05:45 PM
Kingglide549's Avatar
Kingglide549
BDL is making a very nice clutch set up that goes with their belt drives.
I have not put mine to use yet as I am in many pieces. (bike)
Old Nov 7, 2018 | 09:39 PM
johnjzjz's Avatar
johnjzjz
it comes down to what your doing - hand clutch requires a good one - foot clutch a cheaper alto works well
what size belt you have in mind I have a used 3 inch we are not using on the one job we are doing that it had
Old Nov 8, 2018 | 05:33 AM
badfl97's Avatar
badfl97
I’m going with a 2” belt , will I need a puller To remove front pulley?
Old Nov 8, 2018 | 05:43 AM
Kingglide549
Nope.
A long breaker bar or the impact.
Then there is the argument if you hurt the bearings using one. (impact)
Old Nov 8, 2018 | 06:24 AM
johnjzjz's Avatar
johnjzjz
the bearing is not the issue using an impact gun - what actually happens is the shock wave caused by the rattle gun can and does move the position of the tapers in the flywheels - it screws up the wheels true -- the 3 with key ways are not affected ( as much ) as the crank pin one side that does not have a key way
then we come to the AMF idea the sprocket shaft did not need a locking key way - well 1000s of guys will tell you that was not a good idea -- because they experienced the shaft spun in the flywheels - did it come from the rattle gun of popping the clutch both do the same thing
