think I maybe the only one with this problem
Old Dec 29, 2018 | 12:50 PM
1981 suprglide's Avatar
1981 suprglide
Default pressure in oil tanks
where do the pressure in my oil tank come from? is it the oil pump?
I have a stock oil tank and the lid won't stay secure I have to use a freeze plug
how do I reduce the pressure in my oil tank? and hey if you have an horse shoe
tank you may not have this problem I run power factory 60 wt oil
Old Dec 29, 2018 | 01:10 PM
hellonewman's Avatar
hellonewman
I think you need a twinkie engine
Old Dec 29, 2018 | 01:58 PM
1981 suprglide
yes I have one but haven't changed the cam chains yet but it runs like a champ love it
and thanks
Old Dec 29, 2018 | 02:07 PM
panz4ever's Avatar
panz4ever
Stock oil bag from 71-E82 had the filler on top with the screw on cap (for lack of better description anyway) and also had the oil dip stick on the left side. Is it the top cap that is not staying secured or is it the dip stick?
The oil cap assembly is pushed down and the top lock basically screws it into place. Never seen one that was broke before.
If it is the side dipstick that is loose then I would suuget that the rubbber around the dipstick is worn beyond use. That occurred with my 84 FLH and I recently replaced it with an extra from my stash.
Old Dec 29, 2018 | 02:16 PM
1981 suprglide
wow you described mine perfect it is the dipstick it will not stay on
it goes into the garage wall when I try start the bike, right now running
a freeze plug I changed the rubber element last year and it didn't help
Old Dec 29, 2018 | 02:50 PM
Racepres's Avatar
Racepres
Some Serious Blow-by issues... or... The Plumbing is Very Wrong...
I suggest you have someone who knows unequivocally... how the bike is Plumbed..
If you plug the Crankcase vent this will surely happen... or other Ooops es
Old Dec 29, 2018 | 02:56 PM
johnjzjz's Avatar
johnjzjz
the engine has a vent on the inside of the oil pump - 2 things come to mind you could have the vent going directly into the oil tank - that will do what your explaining seen it before
the vent can be squashed some how it transit from one owner to another also seen that
the engine is severely tired and the blowby even with the lines connected correctly it will also do that -- seen that as well
pans has a oil pump photo of what and locations of all the oil lines and vents - maybe he will post it so you can go visit this issue
have you ever drove this for any length of time as an owner is a good starting point
Old Dec 29, 2018 | 03:02 PM
1981 suprglide
ok I'm busted I didn't plug it I just installed a one way valve on it so it can't suck
air in but air is coming out guess I'll remove it and see what happens
Old Dec 29, 2018 | 03:06 PM
johnjzjz's Avatar
johnjzjz
I am not going to ask but --------------- you cant fix
Old Dec 29, 2018 | 03:28 PM
1981 suprglide
removed the one way valve no improvement I'm back to the freeze plug maybe stuck
with this freeze plug for real
