Overheating?
Old Feb 8, 2019 | 10:05 PM
johnjzjz's Avatar
johnjzjz
Originally Posted by Kingglide549
Yea after a LOT of miles, and I, and we have to presume he is not asking about pistons and overheating in that situation.
So if these are in a newer rebuild there is a LOT of wear going on there.
I kind of sort of perhaps understand Rod ratio- Currently putting halve inch longer rods in this other HIPO engine we have going together here.
The longer the better usually.
longer rod will get you an extended dwell time at TDC - with that you can adjust with compression to take advantage of the longer squish
having said that the most power comes from a short rod as it snaps off the deck and in that the HP / torque goes way up
Old Feb 8, 2019 | 10:07 PM
johnjzjz's Avatar
johnjzjz
the 1.87 is a 3 31/32 stroke
Old Feb 9, 2019 | 06:29 AM
Kingglide549's Avatar
Kingglide549
Of course, this depends on which engine we are talking about.
The Vtwin is under constant migration of evolution in peoples shops.
As I said in most cases a longer rod is a good thing (rod ratio)
I was referring to this HIPO boxer above.
This boxer I am redoing will benefit from a longer rod, certainly, you are correct about the Vtwin
I prefer over Sq. HD transparently does not.
Old Feb 9, 2019 | 09:03 AM
SparkyD's Avatar
SparkyD
I was referring to the black burnt look on the sides of the pistions. This bike definitely has a LOT of miles on it. I have spoken with the 3 previous owners, all in this area. One of them even commented "wow! that thing still runnin?"
steelerdude1
Oct 7, 2014 09:16 AM
cpc0812
Softail Parts
Jul 18, 2014 04:42 AM
Drjas
Nov 13, 2012 07:38 AM
HDSTORMDANCER
Jun 27, 2006 07:10 PM
