Baker 6 to 4
Old Apr 9, 2019 | 05:37 PM
Bri894's Avatar
Bri894
Default Baker 6 to 4
Are any of you guys running a Baker 6 to 4 trans on your Shovel? I have the opportunity to buy one for my shovel and I wanted to see if you are happy with the upgrade?
Old Apr 10, 2019 | 08:53 AM
1981 suprglide's Avatar
1981 suprglide
wow we talking dollar, dollar bills yall
Old Apr 10, 2019 | 09:16 AM
Racepres's Avatar
Racepres
Baker don't make no Junk
Quality will be remembered ... Long after Price is forgotten...
Old Apr 10, 2019 | 11:57 AM
garystaven88's Avatar
garystaven88
What's the specs on your Shovelhead? 74"? 80"? More than that?
Old Apr 10, 2019 | 01:47 PM
Bri894's Avatar
Bri894
I have a dual plug head, 93" stroker kit in it.
Old Apr 10, 2019 | 02:36 PM
garystaven88
Should work well for you. I dont have first hand experience with the 6 speed but I hear if it's a stock Shovelhead it will have a tough time pulling 6th.
Old Apr 10, 2019 | 02:50 PM
Racepres's Avatar
Racepres
I do Not believe they are all Overdrive... if ya get one that is Not, the smaller motor can certainly benefit..
and even if Overdrive... change sprockets, and have even more fun...
Old Apr 10, 2019 | 11:48 PM
scootertrash's Avatar
scootertrash
You may want to look at the installation instructions on Bakers websight .There are a few modifications you may or may not want to do. Also .because the transmission sticks out a couple inches farther on the right side., Your exhaust selection is quite limited. I have had one in a 106 inch stroker for at least 5 years.with a ProClutch,the best primary chain I could find,cal custom inner primary. and a solid steel transmission plate. I beat it pretty good and it has held up. The only bitch I have is that with the exhaust I have ,I couldn't use the Baker kick arm.
Old Apr 11, 2019 | 04:27 AM
Bri894's Avatar
Bri894
Thanks scooter trash, that's the kind of info I was looking for
Old Apr 11, 2019 | 04:50 AM
Hoginedgewood's Avatar
Hoginedgewood
I will second Baker quality. That's an expensive way to get overdrive. Overdrive robs horsepower vs a 1 to 1 final drive.
