No fire part 2
Old May 8, 2019 | 06:46 PM
Dumd ass's Avatar
Dumd ass
Default No fire part 2
Did some current tests as suggested.Tested current on top of the coil Showed 10.2.Heres where it gets strange.I removed ignition wires and retested.Coil showed 12.6 top and bottom.Hooked ignition wires back up it showed 10.2 again???
Old May 8, 2019 | 07:52 PM
johnjzjz's Avatar
johnjzjz
bad battery don't care if its brand new - it has no ability to take a load
Old May 8, 2019 | 07:56 PM
Dumd ass's Avatar
Dumd ass
Default Fire
That's 2 new batteries in 10 days 310 cca
Old May 8, 2019 | 08:29 PM
hscic's Avatar
hscic
What voltage do your batteries read? Did you or the supplier charge the battery when you bought it? Place the battery on a tender to charge overnight.
Old May 8, 2019 | 08:34 PM
Dumd ass's Avatar
Dumd ass
Default Fire
Both batteries showed 12.6 .I did put it on a 1.5 amp. tender
For 12hrs.She showed charged in 6
Old May 15, 2019 | 07:32 PM
coax9952's Avatar
coax9952
A Battery Tender is NOT a Charger....It is a Maintainer, you will not get a complete charge to the battery unless you have a 6 amp CHARGER or higher. A tender will only bring it up to the rating of the unit....
Old May 16, 2019 | 07:56 AM
Racepres's Avatar
Racepres
Actually I have an original 1 amp motorcycle Charger that works perfectly... calculate charge required, based on Voltage, then charge for how many hours required to bring battery to 100%... perfect!!!
Do Not ever, overcharge...it is the absolute number one Killer of lead acid batteries!!! ask any [honest] battery person...
Old May 16, 2019 | 10:48 AM
coax9952's Avatar
coax9952
A charging Device of any kind will only do so up to the amperage rating it puts out..... Batteries only store that voltage/ amperage to probably maybe 1 Volt/amp above the chargers rating. That's why when your rides charger is running at full tilt it runs at 14+ Volts, and (if stock) up to 22Amps output.....
Old May 16, 2019 | 11:05 AM
Racepres's Avatar
Racepres
Charging rate... Yes.. That's why it takes a 1 amp charger twice as long to bring a Battery up to the same potential as a 2 Amp...and 4 times as long as a 4 amp...
I prefer Not to be in a hurry..Amps is Amps, and Volts is Volts..
My old 14 amp Charging system does just fine...as I do Not have much "draw"... don't even run with the Lights on..and Kick start normally also...But, it is not at it's best when hooked to an AGM battery..Which seem to take a higher Voltage [potential] vs a Conventional flooded cell battery...
All them amps is for "Accessories"
Old May 16, 2019 | 05:24 PM
Dumd ass's Avatar
Dumd ass
Default No fire
Thanks guys I appreciate the help
2013superglideseattle
Jul 29, 2017 10:05 AM
deadrubberboy
Feb 19, 2016 01:51 PM
Reign83
Shovelhead
Jun 29, 2014 07:03 PM
essentialcycle
Jul 16, 2010 06:52 PM
clove07
Shovelhead
17
Aug 17, 2009 11:41 PM
