Throwout bearing fork
Old 05-07-2020, 07:22 AM
Fastty's Avatar
Fastty
Fastty is offline
Default Throwout bearing fork
changing out throwout bearing on a 78 fx, the fork needs replaced, anybody know if the fork is a press fit on the shaft? if so how do you get it apart?
Old 05-07-2020, 08:16 AM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,056 Likes on 1,511 Posts
Basically pops right off... But, It is Not a Wear Item... the Bearing is... note tho, they can be broken... seen a few... some I believe were misadjusted such that the Fork contacted the MainShaft!!!! Look this over carefully so you understand the Why, of Clutch Adjustment... it will pay Dividends!!!
Edit; BTW any minute now someone is going to bring up the Superiority of the Old Style "bell" throwout
True for O.E. Throwouts... but, having seen the insides of a Chiwanese Bell type Throwout... I am Decidedly Not Gonna!!!!
Note How long the OE wafer really does Last... IF adjusted Properly..
Old 05-07-2020, 01:35 PM
Fastty's Avatar
Fastty
Fastty is offline
my bearing went out and chewed up the fork. the last time i replaced the bearing was probabley 15 years ago. but i never had to replace the fork wasnt sure if it was a press fit or if there was a retainer on the end of the shaft
Old 05-07-2020, 02:56 PM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,431 Likes on 889 Posts
there's a clip at the end of the shaft, then the whole thing comes apart easily. Don't lose the washer either
Old 05-07-2020, 03:35 PM
Fastty's Avatar
Fastty
Fastty is offline
Thanks for the info guys
Ultra RB
04-24-2023 02:35 PM
bellgnte
05-24-2016 10:04 AM
road99glide
10-05-2008 08:43 PM
JRBIII
04-19-2008 01:05 AM
maineultraclassic
03-17-2008 05:47 PM
Quick Reply: Throwout bearing fork
