Where did Harley Davidson go wrong?
Old Jul 7, 2020 | 07:59 PM
Kawickrice's Avatar
Kawickrice
I have a 70s jap bike that had a nylon rear drive sprocket. The sprocket was pretty durable until you did burnouts then it would shear the teeth right off and turn into a plastic disk. What were they thinking.
Old Jul 7, 2020 | 08:00 PM
Scout's Avatar
Scout
Harley did not go wrong.
The internet arrived and allowed everyone to get on and bitch about everything.
I ride an 01 ultra. Twin cam with tensioners. MM. Had it since new. Over 200,000 miles on it.
Yes, I had to maintain it. Just like bikes before. Yes, I broke down. Just like before. But after all the Wings, Shadows, Ventures, etc, etc, before, I still ride and love the old 01 HD.
Old Jul 7, 2020 | 08:17 PM
TwiZted Biker's Avatar
TwiZted Biker
Aftermarket picked up that idea for HD's in the late 70's, wasn't long after you started seeing them in junk boxes at swapmeets.
Old Jul 7, 2020 | 11:09 PM
Turbomunkey's Avatar
Turbomunkey
Interesting and unexpected replies thus far.
Old Jul 10, 2020 | 10:45 AM
panz4ever's Avatar
panz4ever
Where did Harley go wrong....planned obselesence after phasing out the EVO platform
Old Jul 10, 2020 | 10:57 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Please explain.
Old Jul 10, 2020 | 02:42 PM
coax9952's Avatar
coax9952
You build a Bike that lasts 50 years, You can't sell them replacement motors and 50$ T Shirts....
Old Jul 10, 2020 | 02:56 PM
johnjzjz's Avatar
johnjzjz
twinkies and i dont work on them - you need a 50 ton press to do the flywheels - we teach in the shop the guys who want to learn - no way i would let them do that operation they could with a mistake get killed - AND why did they make them round when they knew in the 70s the top fuel sportys were 6 point crank pins flywheela and pin holes - they were like an allen wrench - never going to scissor and do not need that amount of press - and are serviceable - not the round at 50 tons (thats 100,000 pounds ) nothing survives the squeeze - looks like a throw away to me
the cams - chains and inferior plastic tensioner's - surround the oil pump in a cast alloy shell - NO alignment tool to re set just pins even if they have or might have made a tool - the open cast oil pump cam tensioner housing does not have a memory like a T6 forged AFTERMARKET piece - that holds it and does not allow the oil pump to trash out - looks to me they cheeped it as much as possible - and who pays the dealer repair at a couple grand each time - it was all the talk back then it seem like a good many trashed out of warrantee go figuer - ok they changed the plastic pad 5 years later but did not up date the design till 07 - really
at the dealer when i needed odd stuff my then dealer that is closed today - they always had completely torn apart changing frames < what was that about
its like a drinking favorite - you have your idea and others have other ideas - i am told the bugs are all gone but at whos expense
Old Jul 10, 2020 | 03:22 PM
TwiZted Biker
Please explain.
My post covers some of that, we as a nation have moved away from a repair or rebuild mentality to a replace it mindset. An example, refrigerators or other major appliances that were made in the 40 & 50's are still working, try buying one today that'll last 10 years.
Same with bikes, they have a designed life span, once past that it's more cost efficient for a number of reasons to replace than rebuild it. Designed obsolescence.....
Old Jul 10, 2020 | 03:29 PM
Turbomunkey
If hindsight is 20/20 then I’ll just keep buying older vehicles. I didn’t blindly purchase my twinky thinking about how cool I would look putzing down the road, I have several reasons. One can’t argue with buying a bike that left the dealer new for over 20,000 OTD for less than half that price with a meager 14k miles on the ticker. Also being a 2011 it’s got the “new and improved” hydraulic tensioners that don’t come apart at 20k miles and clog your oil pickup. I’ll putz around for a few years then when it gets cold throw it up on the table and replace the plastic shoes, maybe cams if the stock ones look like crap, as I’ve heard they aren’t hardened properly. I also have a 2000 F250 diesel I picked up cheap. Starts and goes every time, needed some tlc being a 20 year old rust belt truck. All of the companies or guys with deep pockets got to iron out the problems that came with the post emissions 6.0s and 6.4s and I got to read about it all a decade after the fact.
