Howdy All...i am needing to build a custom rear brake line for my 79 FX. The JP cycles catalog fittings are designated as AN-3 type but they dont say what years they fit for. Do shovels fit under that AN-3 designation?
thanks in advance,
rick
Nope..AN fittings are a tapered fitting most often associated with Aftermarket braided lines..
O.E are steel...automotive Inverted Flare [Double Flare] lines..
I get various lengths at NAPA
BTW make sure a middle portion of the line is flexible, as the Swingarm moves ... right??
Thanks Racepress! Yep, the main run will be hose. Now to track down a fitting with 180 degree turn from the front master to get everything headed towards the back end.
probably 1/8 Pipe coming from the MC... Look to Verify, as it too may be Double Flare..
If double Flare then the steel Automotive tubing can be bent into a circle even if need be, By Someone who has done it before...Again My NAPA store!!!! If 1/8 Pipe... any Hardware store has a 90 degree Elbow [brass], then the 90 degree 1/8 pipe to double flare..equals 180!!!!
You definitely need to make friends with either a NAPA, or a Brake type Place
Looks as good as O.E. probably worth a try!!! Hope it ain't Imported!!!!
Last I knew a place called Throttle Masters, they were in Florida!!!
Could easy be more than One tho!!
