Relays
Old Oct 21, 2020 | 10:27 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
A quality aftermarket relay is: Bosch 0332019155 (this unit has a mounting tab molded into the case).
Relay without mounting tab: Bosch 0332209152.
These are both diode protected relays.
When using a diode protected relay, keep in mind that pin 85 must be connected to ground.
When using a resistor protected relay either pin 85 or 86 can be ground.
Old Oct 21, 2020 | 12:04 PM
Racepres's Avatar
Racepres
Sorry Marty.....
It`s now a spare in the junk drawer of my workbench......
I see how you are...
BTW you be at Rockingham in a Couple weeks???
Oh... And Edit
But not Both!!!
"Blowing Rasberry"
Old Oct 21, 2020 | 01:32 PM
DooWop's Avatar
DooWop
I'm not worried about the relays. 40 amp resistive, 30 amp inductive. For the most part Amazon doesn't sell junk and what isn't made in China anymore? BTW the supplier of these relays gives a phone # with a 10 hour response time for problems.
I have bought other parts w/o problems.
Before retirement my business was with controls, both electro-mechanical and digital (hvac). China is the source for a lot of controls and they are looking for even cheaper labor. I would like to buy USA for everything but Globalization has manufactures by the short hairs. I have little confidence that suppliers of most of our MC parts are the US. It's rare enough that JP tags USA parts in their catalog.
Unfortunately there is no good way to tell if a relay is quality by looking at it. If the relay fails I will eat crow and tell you about it.
Old Oct 21, 2020 | 02:01 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Well, for one thing, Bosch relays aren`t made in China...
I know one way to tell if a relay is good, look on it to see where it is made, if it says China it is most likely junk, if it says Bosch, Tyco, Hella, or TE on it, you have a quality part.
Sorry to disagree, but 10 bucks for 10 relays=cheap chinese junk.
Old Oct 21, 2020 | 08:06 PM
Racepres's Avatar
Racepres
^^ I am Firmly in Dan's corner on this... Not by "marketing" nor "Budget", ... but by "Experience"
But, I do Not use folks like J&P.... Ever... I have an Indy... Indispensable!!!
Old Oct 21, 2020 | 08:48 PM
DrDirty's Avatar
DrDirty
I found a circuit breaker and turn signal and 4 way flashers at NAPA and it is all working well so far. They aren't the cheapest but readily available.
Old Oct 21, 2020 | 09:04 PM
TwiZted Biker's Avatar
TwiZted Biker
My poor broke days I’d hit a junk yard and yank couple of the Bosch relays from ero imports. As been said several times the $10 for 10 deal isn’t, they let smoke out pretty quick.
Your going to do it so be sure it’s mounted somewhere easily got to quick and carry an extra, you aren’t breaking any new ground with this idea.
Old Oct 21, 2020 | 09:26 PM
DooWop's Avatar
DooWop
Saying relay is poor quality because of where it's made isn't logical. You don't have any history of it failing.
Another question is how much does your expensive relay actually cost to produce. Because of our marketing model in our country every tier gets their end.
Old Oct 21, 2020 | 10:41 PM
DrDirty's Avatar
DrDirty
I really wasn't addressing the difference in quality because I haven't used either long enough to make a determination. I was just saying that to get my bike going I was able to get some simple electrical parts that are doing the job and all I had to do was walk into the store and purchase them. I can't walk into the local HD dealer and buy parts for my '79 so I am doing whatever is necessary.
I probably won't be packing any spare flashers and turn signal circuit breaker, I have a left hand for a backup.
Old Oct 22, 2020 | 04:35 AM
Dan89FLSTC's Avatar
Dan89FLSTC
I didn`t say it was junk because of where it is from, I said it is junk because it is cheap, and from china.
All low priced crap from China is junk, cheap electrical parts on ebay, cheap tools at Harbor Freight etc, it is junk.
And cheapskates keep buying the junk, and the quality stuff disappears.
When I have a choice, my money doesn`t go to buying junk (especially chinese) I spend the money and buy quality stuff.
If you want to use that garbage, be my guest.
