1968 FLH Clutch Issues
Old Apr 28, 2021 | 06:03 PM
johnjzjz's Avatar
johnjzjz
Is the plan what - to fix it - a 68 will have a real throw out bearing not the newer just they went to - but a moron could have converted it to the newer type as we convert newer ones to the early one - that is almost indestructible - i said almost morons can accomplish almost anything
exhaust off original primary has to come off later one just the derby cover to slack off the screw for the push rod
pop off the cover it may or may not have a kicker - if it has — hold the kicker when removing your wrist will thank you
Old Apr 29, 2021 | 09:42 AM
Will Mcdonald's Avatar
Will Mcdonald
3rd Gear
The throwout bearing and slinger must still be attatched since I couldn't pull it out through the basket side. Would a bad-wornout throwout bearing make it hard to pull the clutch in?
Thanks
Old Apr 29, 2021 | 10:27 AM
johnjzjz's Avatar
johnjzjz
Seen them wear the foot off the lever pad making it flat instead of a 1/2 round - no mechanical advantage does all kinds of things
Old Apr 29, 2021 | 11:20 AM
Will Mcdonald
3rd Gear
Thanks, I'm gonna take off the kicker cover tonight and see what I find.
Olduj
Dec 16, 2020 06:25 AM
Will Mcdonald
Shovelhead
Sep 18, 2020 07:56 AM
Rick York
Jul 1, 2020 09:38 AM
HarleyX89
Mar 24, 2010 11:36 PM
goutieboy
Mar 3, 2009 08:27 PM
