Another head question
Old May 24, 2021 | 06:51 AM
Scruffy 1's Avatar
Scruffy 1
Default Another head question
On my 83 shovel, progressing through the rebuild. I removed the cylinders and pistons. I am taking them to the machine shop to have them "miked". I don't have a bore gauge. I did mike the pistons and both the front & rear mike out at 3.495 at 90 degrees to the pin. The front piston has a " 4 B" marking and the rear piston has a " 6 B" marking. My understanding is the "B" marking is the grind. Don't know what the 4 & 6 designate, other than location. ?? The bike probably is a 7.4:1 compression ratio. The pistons look in great shape, so waiting to see what the machine shop says after inspection. I just soon reuse the pistons and cylinders if all is well. 7.4:1 is pretty lame, but ...
Old May 24, 2021 | 07:18 AM
johnjzjz's Avatar
johnjzjz
The numbering system is in house factory for grading and sizing on assembly line - common stuff
had you pictured up and asked the guys would have given an opinion to re use with just ball honing and moly ring set
Old May 24, 2021 | 07:20 AM
johnjzjz's Avatar
johnjzjz
So you CC the combustion chambers and processed the piston domes to get the compression numbers 7.4 to 1
Old May 24, 2021 | 08:39 AM
Scruffy 1's Avatar
Scruffy 1
No, I am using the info from my service manual. It list my bike to have 7.4:1 compression ratio. I have no idea what the cranking compression is. I did a cold cranking test (psi) before tear down. I didn't do a leak down test. The front cyl was 90 psi & rear 100 psi. When I pulled the cylinders, the front piston had a broken compression ring (top ring). There is no scoring on the cylinder. Not sure when that happened, but after examining both pistons, I can tell there is a bit more carbon build-up on the ring groove and ring on the front piston. I can send pics, but not sure what profile of pics to send. I have cleaned the pistons with scotch brite pads and have removed most of the carbon.
Bill C
Exhaust System Topics
May 1, 2010 09:01 AM
unclebuck50
Shovelhead
Apr 3, 2010 07:32 PM
ironbutt4sure
Shovelhead
May 2, 2009 04:25 PM
Night Hog
Jun 23, 2008 04:05 PM
lowleveldriver
Apr 6, 2008 08:54 AM
