Lifter question
Old Jul 30, 2021 | 12:08 AM
Gappy's Avatar
Gappy
Default Lifter question
My 83 flht has rebuilt top end all stock except bore and pistons which are 30 over. New A2 cam and new hydraulic lifters.
I have read and followed a few builds in this forum and I can never tell what is best to use as far as lifters, solids or hydraulics. All of my other bikes ( bmw and Moto Guzzi) have solid lifters and I adjust and set them myself. This is my first shovelhead and have no experience with hydraulic lifters. My bike stars and runs well, real quiet and smooth until it is warmed up after a mile or two and things loosen up and your hear the rockers clacking and and I think I hear some ticking from the lifters. I assume this is normal. My question is what is best for my bike Hydraulic or solid lifters. What are the advantages or disadvantage between the two? I have no problem adjusting the valves periodically if that is the way to go. Or should I just leave it alone and forget about it.
Old Jul 30, 2021 | 08:16 AM
johnjzjz's Avatar
johnjzjz
Noise comes from rocker arms having too much side to side movement
noise comes from the lifters in the lifter blocks has a bit more play then new
and sure some could be the lifters - could you add 3 nut flats to the one you find making some sound sure -
adding solids the noise is even more - reason drag pipes were invented
Old Jul 30, 2021 | 09:17 PM
fergerburger's Avatar
fergerburger
I knew John would weigh in on lifters - most people complain of noise on start up from valve train - not after warmed up - would suggest you may have some worn tolerances in rocker arms or lifter bores - could also be thin oil not holding in the lifter - solids will help you get rid of weak lifters and guarantee your lift is on spec - but they are noisy - go by the cam spec on solids or hydraulics - bigger lift (over 450) go solids as a general rule - lifters are a major topic on almost every HD forum - I'm surprised others have not chimed in here - John may know how much lift is lost with HD lifters - typical loss of actual lift is near 030 for many hydraulic lifters - more on the noise - you could also have loose rollers on the tappets - your noise could also be loose clearance on the pinion gear and cam gear - as the lifter rolls over the cam lobe - the force reverses and the gear clicks back against a loose pinion gear
Old Jul 31, 2021 | 08:09 AM
johnjzjz's Avatar
johnjzjz
Its .060 Ferg reason they fall off after 5000 — stock they go back to 350 lift
evo hydro solids pump out and add .060 to the lift at 6800 and stay to top rpms - we have had rockers crack top covers from hitting them at hi RPM and then they leak oil
Matty_d
Engine Mechanical Topics
Jun 18, 2021 05:59 AM
johnod
EVO
32
Jan 4, 2016 02:20 PM
gipper
Mar 14, 2015 08:09 AM
ionhd
Exhaust System Topics
Mar 3, 2011 10:42 AM
96roadking
EVO
Apr 22, 2010 03:15 PM
