Alternator/regulator problem?
Old Sep 16, 2021 | 01:25 PM
crb2855's Avatar
crb2855
Default Alternator/regulator problem?
Hello folks,
I'm putting a friends 1972 FLH back together for him, working on the wiring and things are going well but when I put his regulator back on and was still running the wires to tail lights and to test to make sure which wire was the brake light I hooked up the battery and got an arc. So the last thing I did before it arced during testing was the regulator so I unplugged it from the case and no arc. I'm not electrically inclined so does any one have any ideas, bike is not ready to run. Oh I did put an ohm meter on all the pins in the case and on the regulator to ground and got no reading if that helps. Thanks.
Old Sep 16, 2021 | 01:42 PM
Scrmnvtwins's Avatar
Scrmnvtwins
I assume you have a 2 pin connector plugged to the block which is the stator assembly. the only other connection is a single wire from the regulator to the battery.
If you have an arc when you plug the 2 pin connector and the arc goes away when you unplug it...... you have a stator shorted to ground inside the inner primary.
Use an OHM Meter, set it to beep, touch 1 lead to the block and touch each of the 2 pins in the block connector. If you get a beep the stator is shorted to ground somewhere.
Old Sep 16, 2021 | 02:18 PM
crb2855's Avatar
crb2855
Thanks for the reply, It is a 4 pin connector and I have tested the pins both for ohms and also set to beep and nothing, the stator doesn't seem grounded by those checks.
Old Sep 16, 2021 | 02:37 PM
chopper_man's Avatar
chopper_man
Where is the wire out of the regulator going? Should be going to the positive terminal of the battery.
Old Sep 16, 2021 | 02:57 PM
crb2855's Avatar
crb2855
It is directly to battery plus, and I just thought to check continuity between the four pins in the case and there is between all the pins it doesn't matter which what does that mean?
Old Sep 17, 2021 | 09:20 AM
Scrmnvtwins
I am not sure about a 4 wire stator but I assume it is 2 separate sets of windings around the stator. The stator generates alternating current (AC) same as your house electrical plugs. The regulator converts that alternating current to direct current (DC) If you have a short between the 2 sets of windings you would have a short between the phases. I would expect 2 pins to be both ends of 1 set of windings and 2 pins to be both ends of the 2nd set of windings. I would not expect any pin to have continuity to more than 1 of the remaining 3 pins.
You have 1 phase going positive and 1 phase going negative creating alternating current (AC) from the stator. I would think if you are getting continuity between any of the 4 plugs you have a short between phase windings on the stator. Imagine taking a wire and putting 1 end in 1 side of the electric outlet in your home and the other in where the other blade of a standard plug goes, "BANG" a short and may pop your breaker. Your regulator is seeing that same thing.
Old Sep 17, 2021 | 09:57 AM
Racepres's Avatar
Racepres
I will assume, (not good) that if the 4 pin plug to the case is the problem... since the regulator is still attached during your tests... that a winding in the Alternator stator, or a pin itself, is Grounded...but hard to troubleshoot from a keyboard...
Old Sep 17, 2021 | 05:35 PM
john lee's Avatar
john lee
sometimes the pins are the problem i had an external plug fitted as my pins were burnt
Old Sep 17, 2021 | 05:45 PM
TwiZted Biker's Avatar
TwiZted Biker
The old 4 pin 17 amp stator systems had a habit of eating regulators, went through 4 of them on my 72. Dumped everything and went to the later 32 amp stator & reg and haven't had an issue since.
PS you do the swap use the original rotor on the bike now not the repop on that comes with the kits. Contrary to what gets said it works just fine and is a beefier design than the cheap import replacements.
Old Sep 18, 2021 | 06:29 AM
crb2855's Avatar
crb2855
Thanks for all the reply's, I found the information I needed in an old Clymers manual. The regulator is toast but the stator passed the tests. The book had a a good write up of how to perform the tests with an multimeter and a diagram of the pin layout and the internal layout of the regulator.
