headlight
Old Dec 10, 2021 | 02:11 PM
john lee's Avatar
john lee
Default headlight
i had to solder a wire inside my fx narcelle wow why is there so many wires in there. a jungle of wires. i thought id see a headlight plug and 2 blinker wires.at most. not the case
Old Dec 10, 2021 | 03:17 PM
johnjzjz's Avatar
johnjzjz
They hate people like you that work on the own bike so they made it easy for them and U they did not care so much for
Old Dec 10, 2021 | 03:46 PM
hellonewman's Avatar
hellonewman
My FXR is the same, I couldn't believe it. I wanted to put in an LED headlight bulb - HA! Ain't happening with the big heatsink hanging off the end.
Old Dec 10, 2021 | 04:45 PM
johnjzjz's Avatar
johnjzjz
In canada the discussion about a LED headlight takes a turn for the worse BUT his heat sink is sticking out in front
Old Dec 10, 2021 | 05:41 PM
hellonewman
We're hoping to get some American input on that topic.
Old Dec 10, 2021 | 05:51 PM
carlgrover's Avatar
carlgrover
Jeez, my glasses broke when I saw those two pics.
When I got my shovel I had to do a ton of rewiring and I spent a lot of time in that nacelle. I figure the reason there are so many connectors in there is so they could prewire subassemblies then just make the connections real quick at final assembly.
carl
Old Dec 10, 2021 | 07:14 PM
johnjzjz's Avatar
johnjzjz
Old Dec 11, 2021 | 12:40 AM
Squidbilly*'s Avatar
Squidbilly*
As long as your not colur blind and or gender blinded you'll be fine,
Old Dec 11, 2021 | 05:43 AM
Cobra1's Avatar
Cobra1
I just re-wired my 81 Fatbob and thought I would clean up the wiring behind the headlight. Not really possible if you keep all the buttons and switches. It adds up really quick.
Old Dec 11, 2021 | 07:24 AM
Racepres's Avatar
Racepres
This!!!
I have done more than a few.. all with O.E. connectors and Color code... I am continually amazed be the sheer number of folks who do Not Realize that the HandleBar controls are Modular...each side with it's own harness then a lighting harness then an ignition/control/information harness...all modular... ie. No Need for Wire Cutting.. a small bit of Thought and Effort before the wire cutters!!!! Even the MoCo made different length harnesses...
