Pushrod seals
Old Mar 17, 2022 | 01:47 PM
commander47's Avatar
commander47
Default Pushrod seals
I have a 77 Shovel. I bought a top end gasket kit, and it came with O rings for the pushrod seals.
Can these be used in a 77? I'm used to the cork ones.
Old Mar 17, 2022 | 02:35 PM
johnjzjz's Avatar
johnjzjz
Cork only
Old Mar 17, 2022 | 03:29 PM
john lee's Avatar
john lee
Originally Posted by johnjzjz
Cork only
is cork an upgrade. my 80 still has the o ring and hasnt leaked since 84 when i bought it
Old Mar 17, 2022 | 03:59 PM
Joe12RK's Avatar
Joe12RK
They changed the shape of the tubes when they went from cork to o-ring. One won't fit the other properly.
Old Mar 17, 2022 | 04:11 PM
johnjzjz's Avatar
johnjzjz
and i thought it. Was because you are up side down
Old Mar 18, 2022 | 11:34 AM
commander47
Thanks everyone.
I definitely have the old style Steel pushrod tubes. Good thing I checked here. I've replaced them many times and always got cork, I didn't realized they were upgraded to aluminum tubes.
Anyway, I opted to order the rebuild kit with silicon seals that are supposed to be better than cork. They cost more, but not much.
I hope the silicon seals aren't a waste of money.
Old Mar 18, 2022 | 05:22 PM
johnjzjz's Avatar
johnjzjz
Yes they are
Old Mar 19, 2022 | 12:24 AM
fergerburger's Avatar
fergerburger
dont let JZ bum you out - the blue silicone seals will work - o-rings will also work - quad seals are the newer style o-rings that are used with the newer push rods that have a lip on the bottom tube - you can see the lip on the bottom of the 81 tubes in the pic - they are not aluminum
Old Mar 19, 2022 | 10:19 AM
johnjzjz's Avatar
johnjzjz
Hope he comes back in may when the blue seals leak - not looking to be right just every bike that has ever come to the shop with them installed was oozing
Old Mar 19, 2022 | 11:21 AM
magnum45pete's Avatar
magnum45pete
mine used to leak with corks so got the blue o rings & it was cured,
but did once have good luck by soaking the cork o rings in water for a day before fitting & they also never leaked,
they kinda expand & soften a bit when soaked giving a better seal & dry to the exact shape & angel of the tubes & lifter blocks.
