Spark plug sub
Reason I want to do it is they have a much longer threaded body, probably because the resistor cools it, and it needs to get closer to the piston for the same heat.
I had the short stubby plugs in my bike when I bought it and the threads in the head were pretty shot. I had to but the long thread plugs so there were more threads holding in the plug. Bike runs great. 79 FX
Tom
Lowoilpressure, your '79 if original heads would have been long reach anyway, PO probably installed wrong plugs.
I wrote a long reply last night, and it dissappered, I must have hit the wrong button. I'll try and keep this shorter on why I want a longer plug.
The front plug was only holding by a couple threads, so last year I put a Helicoil in, not that brand, but a "Plug Saver" insert. I have around 1,000 miles on it, and a couple weeks ago coming in from a ride I was thinking how this bike never ran better, it was like music going down the road. I get about a mile from the house, and it starts poppiing, I guessed it was a condenser because this shovel eats them.
I change the condenser, and it still is popping, the front cylinder is noticeably hotter just idleing in the garage, I'm now thinking its the O-riings in the intake. I check that out and its fine. I do a compression check, and the back is 90, front is 35. I pull the front head, and I can see light around part of the helicoil. The thread of the aluminum must have separated.
I take it to an auto machinest, he takes the helicoil out with an easy out, but it destroys the threads. He can't help any more, and sends me to a machine shop.
The machine shop says they have to weld the hole shut, re bore and thread. The weld would be softer than the parent aluminum head, but should last just fine. Thats where its at now, I don't know when I will get it back. I just thought since the plug is so short threaded, and looks like there is plenty of room, a few more threads will help. I just am concerned with the heat range. I thought maybe the resistor plug of the same designation would be the same heat, and it has lots more threads.
If that doesn't work out, I'll probably spring for the S&S head.
The rear head has a helicoil that was installed by a hot rod speed shop. Its been in there over 25 years, and been great.
When I ran 2 stroke dirt bikes, there was a definate difference, NGK were my favorite, Champs were the worse.
