Ignition Advance settings
Old Jul 22, 2022 | 04:27 AM
Scruffy 1's Avatar
Scruffy 1
Default Ignition Advance settings
83 FXSB. The bike originally came with an electronic ignition. Converted to points. Now back to electronic ign. Ultima 53-644. The advance timing mark on the flywheel I believe is 35 degrees BTDC. At what rpm did the factory set to reach 35 degrees advance. The Ultima ign module is programmable. I realize that depending on the bike's condition, a lot of things are in play. The factory probably had certain parameters for there new bikes. Just curious.
Old Jul 22, 2022 | 07:45 AM
johnjzjz's Avatar
johnjzjz
You set the 644 ignition at the front cylinder on compression stroke at TDC only - using a straw in the front plug hole rotate the engine tilll you see what ever shows up at TDC in the block window - set it in the center turn the ignition 644 counter clockwise all the way - turn the ignition on - now slowly turn clockwise till the light goes off - hold and tighten the screws - you done no need to do anything else
do not play captain computer re programmer - you will eff it up and wont get back to the factory setting - that actually work well in the 500 we have installed
Old Jul 22, 2022 | 03:21 PM
Scruffy 1's Avatar
Scruffy 1
Default Ultima
Thks, I was able to get the settings. I realize that the paperwork for the module has the ign advance curves for the different dip sw settings. The default setting for the dead rev is 3. I had to program the advance curve for my bike (curve 1 is default) and set the dead rev to 0 so I can kick it. I can kick start it now. Before, I was carbon fouling my plugs, They are starting to look a whole lot better. Super E. .0295 on the intermediate & .072 on the mains. 140 psi on both cylinders.
Kennys_world
Jan 10, 2022 03:24 PM
sbrmike
Shovelhead
Nov 21, 2020 04:17 PM
Bmp72
Shovelhead
27
Oct 21, 2020 06:50 PM
badinfluence63
Aug 8, 2008 10:07 AM
badinfluence63
Aug 8, 2008 09:01 AM
