Engine case porosity.
Old Jul 29, 2022 | 09:31 PM
joe40x's Avatar
joe40x
Default Engine case porosity.
Early 1977 engine right hand case, just below the rear engine mount, there are several sand holes that combined, leak about a drop a day.
About a100 years ago, when I was working at a dealership, the answer was to Glyptal the interior and put 3-4 coats of paint on the exterior.
Is this still the best solution or are there any newfangled, whiz bang ways of sealing these imperfections?
Thanks in advance.
Joe
Old Jul 30, 2022 | 06:28 AM
johnjzjz's Avatar
johnjzjz
Glyptol is the cheaper idea then welding - but after we weld them we then glyptol the inside any way
but vapor blasting it an add to the idea as if its loaded internally with oil then nothing is going to get all of it
i also have a sonic cleaner tank big enough to use and i use simple green before and after what ever he fix was
today only knuckle and pan or flat head types engine blocks are worth that effort
Lunchboxx
Engine Mechanical Topics
Mar 2, 2023 10:37 PM
Aquadan005
Shovelhead
Apr 30, 2021 07:11 AM
artsbest
Aug 16, 2018 10:55 PM
RodeoHard
Oct 29, 2012 11:53 AM
dlongo8241
Mar 5, 2006 09:00 AM
