Recently I had exactly the same issue, except mine are disc brakes.
I rebuild calipers, master cylinder, rubber lines, and cleared metal lines.
My master cylinder acted exactly as you described. I did all the things you did with the m/c.
After at least 10 unsuccessful attempts at bleeding, I threw up my hands in surrender and ordered a NEW m/c. First bleed after install and the system worked perfectly!
Yeah Im sick of messing with it, so I just ordered a drag specialties M/C. Its not worth the hassle (or the safety concern) at this point, especially given this will be my only brake.
