Skip the red plates then, any will work with the rest of those parts, they do stop the bulk of the common shovel clutch problems. Everybody has their own favorites for this stuff, is what it is.
I am not a fan of the Alto Reds and had issues with them, next time I will get the Barnett ones.
About the long rollers, I remember reading somewhere they will squeeze all the grease out of the bearing, bad for a dry primary.
Each their Own... But I will Take Alto Reds everytime over Barnett
Energy-1 used to have shovel clutches... IDK recently... I always Prefer Energy-1 to Any Other...
i run the plastic tamer that came with the belt kit and the last time i had the clutch apart 25 odd yrs after it installation the 52 rollers were still well lubricated .if some disagree useing the 52 bearings then why would it come with the belt set up ?
The Big 52 as they were called back when was one of many aftermarket attempts at improving the shovel's notorious clutch issues, idea was with full contact long rollers the clutch basket would run true on the hub eliminating the floating wobble that caused dragging, hard shifting, finding neutral ect. Problem is not all the hubs or the basket are same diameter some are tight, some have a looser running tolerance and the long rollers weren't consistent either they tended to be a hair oversized witha micrometer check compared to OEM.
This lead to problems, the most common being they were to tight, clutch basket had to honed out to fit, I've seen several hubs and baskets ruined because of them, one all but welded itself together. Other issue, if they did barely fit they'd cause the basket to walk outward it would literally try to unscrew on the hub, back to dragging hard shifting. If things do fit correctly, in a wet primary they are ok. With a belt you'll be pulling it down regular and lubing them, you can not keep any grease in there don't care what anybody says, 50 miles it's dry and all the grease is now slung up into the plates.
Do what you want but they were one of those bright ideas that didn't work well in the real world.
i must be lucky my bearings are still greased and clutch plates dry
