S&S Super B Throttle Cable
Old Sep 21, 2023 | 10:34 PM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by jimessbee
Right, but that does require the cable get cut because the linkage on the B doesn’t take a barrel on the end of it. This, I’m assuming, is why my cable is a mess as it is.
I’m leaning this direction, but thought perhaps there was some different insight here.
little secret when doing the new cable with no barrel? Install and measure the new exposed cable length you need then solder the section before snipping it. Makes installation much easier. Ran the B for years doing this.
Also the B is prone to wear on the butterfly shaft and carb body, idle not dropping back or getting irregular means she could be sucking air around the shaft, little shot of brake clean at that spot will tell you quick.
Old Sep 21, 2023 | 11:12 PM
Hey Man's Avatar
Hey Man
I got my 1980 FLH running and running pretty well, but it has a Super B carb on it. Whoever put it on mangled the stock throttle cable. So, I'll need a throttle cable. but this has the stock HD cable on it not the dual cable setup that it would appear a Super B ought to have. I do see they sell single cable conversion kits.
Is this what we do? Is my decision to go with that S&S because it was already on there and seemed the popular choice going to cost me another hundred bucks in throttle cables?
A single cable on the "B" carb will work fine if you keep the cable well lubed. But you may feel a bit safer if you hooked up a secondary return spring to the linkage like I did on my Shovelhead. That way you won't have to worry about the throttle not closing when you want it to. Unfortunately I don't have a picture to show you.
Old Sep 22, 2023 | 06:43 AM
jimessbee's Avatar
jimessbee
Your soldering idea does seem like a good idea. Thank you. Will think on it.
Old Sep 26, 2023 | 08:15 AM
Racepres's Avatar
Racepres
The Original Bendix Cable end from H-D, had a brass sleeve, (tube) on the cable...protecting the Cable at the Barrel...
Never encountered a Situation where a Bendix Cable would Not work on My "B"....
Groucho-17SGS
Panhead
Apr 21, 2022 05:45 AM
tar_snake
EVO
Jun 25, 2021 08:53 PM
800screws
EVO
Nov 29, 2015 10:58 AM
cycle75
Nov 18, 2013 04:15 PM
jevanof
Jul 22, 2013 05:45 PM
