Need new shocks for this 76 FXE. Like the look of the cigar tube shocks with the closed tops. Anyone know if a set of switchback shocks will work? Thanks.
Spring rates all wrong on the switchback shocks, the shock mounting position on the old bike is more inboard and takes a much higher rate spring than the later machines.
I have Dyna shocks on my FXS, and like TwiZted says they are very soft. I don't weigh much and it's a light bike so they work good for me. Much better than cheap aftermarket shocks that felt not much softer than solid struts. IDK if you could swap springs to make them work.
So are the switchback spring rates softer? I thought they may be rated differently because its a light touring model. I may be completely off.
You are are completely offin how you think about this, google some big pictures of shovels and the later bikes and look at where the shocks mount on both. The later model machines are way back on the frame and swingarm, the shovels they mount much closer inboard. This substantially increases the required spring pressure to make it work correctly. Myself and many others have been down this road already, the later shocks don't work on the older bikes.
It's simple geometry. Go dig around Progressive shocks website and look up the shock and spring ratings for both, educate yourself before you spend money on something you hope will work.
And you can't swap springs to make it work, lengths and ID's are very different.
That's what I suspected, but thanks for confirming. For a 160-170 lb solo rider on an FX the Dyna shocks work great. All others keep looking, lol.
Fought this battle several times over the decades trying to get decent shocks on my shovel. Stock suck ***** and Progressives ride like brick they are so stiff, jar your teeth unless you are a 300 pounder. Even spent real money trying an Arnott air shock system. Kept blowing the lines out overpressuring due to the angle issue increasing the pressure so much. Bought a set of correct rate springs from Progressive thinking to make them work on FXD shocks by machining adapters, still new in the box $60 wasted after several failed attempts.
Only ones I ever found for shovels that I liked and worked was set from Koni, great for a several years till one day they both blew, dropped the rear on the tire, can't get replacement cartridges for them.
Take a look up inside the fender, bet money you'll see where the tires rubbed it, later shocks have a longer travel than the stock one's, another overlooked issue with this.
