Just Wondering
Old Nov 13, 2023 | 06:56 PM
DooWop's Avatar
DooWop
Default Just Wondering
I've got an 81 Sturgis. I've been bugged by the bike's turn signals for years. As you know, the turn signals are push and hold when your hands should be doing another job.
It's a real bad idea. The newer that detect a turn aren't much better either.
Would there be a market for a latch switch. A latch switch is a push on/push off device I have thought of making for the bike for maybe 20 years. The turn signals bothered me that much.
Using a 555 timer, a latch switch would, I think, be a big improvement.
Tell me if I'm missing something.")
Old Nov 13, 2023 | 07:01 PM
hellonewman's Avatar
hellonewman
I believe there's a kit you can buy with a module that makes the signals stay on.
Old Nov 13, 2023 | 07:29 PM
chopper_man's Avatar
chopper_man
Badlands already makes one. Don't see a big market for them tho.
https://www.denniskirk.com/badlands/...id=17917642306
Old Nov 13, 2023 | 07:49 PM
old mago's Avatar
old mago
i was a bit concerned about turn signals as well when i first got my flh in 2017, mainly locating them without having to look at the handlebars. After riding a bike with no turn signals for nearly thirty years , then jumping on a couple of little japanese bikes to ride to work i found me leaving the signals on.....so i learned to live with them on the HD....switching bikes from one up three down RH shift is fun too
Old Nov 14, 2023 | 01:50 AM
Muskrat21's Avatar
Muskrat21
G'day Bill.
I'm hearing you. Two bikes are right gear shift but one is one down three up, the other is one up three down. The other three bikes are left gear shift one down four up. Makes the first mile interesting and even an hour into a ride I phu(k up!
Had my HD for three years now and still can't get used to the blinker switches on different sides, and often leave them on (sorry fellas it's an early Evo).
Cheers
Old Nov 14, 2023 | 07:04 AM
FL54's Avatar
FL54
Originally Posted by Muskrat21
G'day Bill.
Cheers
I hear you both. I picked up a 1944 BSA WM20 last Spring. Right hand shift one up 3 down. It took some getting used to. I kept up shifting while trying to brake with the right foot.
Old Nov 14, 2023 | 08:25 AM
Racepres's Avatar
Racepres
I guess I thought the MoCo Made a Latching switch??? 1982 - 199???? 6 maybe.. Not for 1973 - 1982...
Will look around as I believe I have one here, but, may be aftermarket!!!!
Old Nov 14, 2023 | 11:33 AM
AJSHOVEL's Avatar
AJSHOVEL
That's why I use hand signals, although these days I have to wonder how many motorist actually know what they mean.
Old Nov 14, 2023 | 11:43 AM
Redrodyankneck's Avatar
Redrodyankneck
I just multi task! I got used to holding the turn signal switch in while doing other stuff like braking and downshifting. It's good for the brain to mix things up, when you don't focus on holding the switch in it becomes a no brainer. You can get a badlands unit like I put on my 94 FXLR but that was easy as all that wiring is in one plce where the OEM cancel unit was. The FXR with the headlight bucket junction terminals would make things more challenging but no worth the effort in my opinion. The badlands unit also allows you to run led's w/o resistors or stock bulbs.The badlands unit I have on my 94 cancels after 20 blinks and that seems to be a fair amount of time.
Old Nov 14, 2023 | 01:07 PM
TwiZted Biker's Avatar
TwiZted Biker
What's this " Turn Signal " you speak of ?
Even on my 17 I use hand signals 90% of the time, never had a bike till the RK that even had them.
