Starting a shovel
Old Dec 22, 2023 | 05:33 PM
john lee's Avatar
john lee
i dont know of any supply chain issues
Old Dec 23, 2023 | 06:20 AM
sbrmike's Avatar
sbrmike
Try MotoBatt. They make a good battery for a good price. They make a battery that comes with 4 poles on top so it will fit a bunch of bikes, i.e. Shovels and later with opposite terminals. They also have spacers to use that same battery in many bikes. There is a spacer to make it taller and a spacer to make it thicker. They give some serious cranking power too. They are imported but not from China (yet, I guess). I have two of them.
Old Dec 23, 2023 | 08:00 AM
FL54's Avatar
FL54
And the results were?
Bike won’t start unless the transmission is in neutral.
Old Dec 23, 2023 | 08:08 AM
FL54's Avatar
FL54
I’ve been looking for either a Ultima Thundervolt or Scorpion AGM Battery for a while now. All the usual vendors are out of stock and they don’t know when they’ll have them. This happened a few years ago as well. I use them because the terminals are in the same orientation as the original lead acid battery. Not a big deal as it’s Winter now and I have other bikes to ride if there’s a break in the weather and the roads are clear.
Old Dec 23, 2023 | 12:51 PM
sbrmike's Avatar
sbrmike
Look into MotoBatt it will work in Shovelhead Lead Acid Configuration as well as the newer opposites. Motobatt MBTX20U 12V 21Ah AGM Battery
Old Dec 23, 2023 | 01:55 PM
Max Headflow's Avatar
Max Headflow
Here is the annotated diagram for a 68-69 FLH
Old Dec 24, 2023 | 08:11 AM
FL54's Avatar
FL54
Thanks Mike. I’ll look into it. No sense buying a battery now anyway as it will be months before the weather turns nice here.
Old Dec 24, 2023 | 01:44 PM
magnum45pete's Avatar
magnum45pete
Kickstarting a Shovelhead
Walk to the bike, fingers crossed, say a prayer....
Ensure all the normal leaks are present....
Look for tranny seal oil spot on the ground to ensure it has fluid.
Turn on the choke.
Kick the bike over a few times with the switch off to get it primed.
Spin it through until you get compression.
Turn the switch on.
Kick until you have to wipe the snot from your face.
Take a break to catch your breath, count the number of people who gathered around, try to look like this is standard procedure.
Realize you are now in middle of the street, roll the bike back onto driveway, that explains the horns blowing.
Try to act as if you don't notice the crowd snickering.
Think, must be flooded.
Turn off the choke.
Hold the throttle wide open.
Kick..kick...kick...
Notice new paint spots on the tank and realize your nose is bleeding.
Wipe the tear/snot/sweat/nose bleed combo from your face.
Cuss.
Kick some more.
Cuss.
Ignore the old man who says......you know, back in the day.......
Kick until you hear horns blowing again.
Cuss.
Don't even wipe, just swallow the combo.
Check the points.
Turn on the choke.
Hold the throttle WFO, kick until the neighbors wife says.......you don't look so good.
Wipe/swallow/cuss
Check the plugs.
Turn off the choke.
Notice you never turned the fuel on.
Cuss.
Turn fuel on.
Turn choke on.
Prime engine.
Threaten motorcycle.
KICK !!
Pick youself up from the ground in front of motorcycle.
Put out the fire in the air cleaner.
Remember to retard the timing this go-around.
Turn on the ignition.
Kick.
Engine starts.......dies.
swallow.
Kick.....success
Check gas in tank, realize there is only about a 1/2 a gallon, meaning you will have to go through this again in about 15 minutes.
straddle bike, look both ways for traffic, realize you are in the middle of the street again.
Ride away thinking........ screw those electric start pooftah's......I'm the real deal!!!
Old Dec 24, 2023 | 02:51 PM
john lee's Avatar
john lee
i just press the button choke on. no throttle starts first go S&S b carby
Old Dec 25, 2023 | 09:08 AM
omar1951's Avatar
omar1951
Turn on the choke.
Turn the switch on.
Turn off the choke.
Cuss.
Kick some more.
Cuss.
Cuss.
Check the points.
Turn on the choke.
Wipe/swallow/cuss
Check the plugs.
Turn off the choke.
Cuss.
Turn fuel on.
Turn choke on.
Prime engine.
KICK !!
Kick.
swallow.
Kick.....success
I love it! Still have my '68 and am in the middle of a rebuild. It had a Tillotson on it years ago, and I still recall performing your starting description years ago. Had a buddy who owned a stock '67. We used to hang at a skeevy Mexican food joint with a parking lot in the back and front. My bud would never park in the front lot, and he would never use the button to start the bike. One night we staggered out of the bar to the back lot and he proceeded to perform your description to a tee. When he finally looked like he was gonna keel over, he looked at me and said "Don't tell anybody you saw this", and he hit the starter button and the bike roared to life!
