Shovelhead left hand trans noise - stops when you pull in the clutch.
Old May 20, 2024 | 04:46 AM
LEZ90's Avatar
LEZ90
Default Shovelhead left hand trans noise - stops when you pull in the clutch.
I’ve just purchased a ’77 kickstart only Shovelhead Bobber fitted with 1340 S&S motor. The bike had trouble starting (was sat for 2 years) so I’ve changed the battery, plugs and coil pack and set the static timing nowt it starts on the first kick.
But I have a couple of issues.
  1. There is a rattle noise from the left when under load but stops when the clutch is pulled in
  2. Rides fine on low throttle but there’s a lull when you squeeze on the power - carb issue or maybe the advance unit ?
Heres the bike: Shovelhead — Les Field Photos
Old May 20, 2024 | 05:23 AM
eighteight's Avatar
eighteight
Wouldn`t be the first noisy shovel clutch
Old May 20, 2024 | 06:17 AM
johnjzjz's Avatar
johnjzjz
You could throw money at it - but they seem to make a come back - its a mans machine not a copy of the jap bike that copied Harley in the first place ie twinkie
some one did a well planed out build lots of never before seen things - like the shaved primary set - the front brake and the mods to it - the alloy rims are choice look - the porker gas tank will keep you young as its only 45 minuet sprint to the next fuel station -
i owned a few DB cars back in the 70s when they were almost free compared to today
Old May 20, 2024 | 01:05 PM
1981 suprglide's Avatar
1981 suprglide
need a Rivera Pro clutch on that I have an S&S SH 93
Rayme010
Apr 18, 2023 08:32 AM
slimshdrdr
Jul 18, 2020 09:03 AM
drbologna
Nov 5, 2017 12:58 PM
Harleyonthebrain
Dec 7, 2012 08:55 AM
gdunz09
Jul 4, 2012 02:03 PM
