Kickstart jammed causing elec. start to not work
Old Jun 29, 2024 | 05:08 PM
Kevin Polzer's Avatar
Kevin Polzer
Default Kickstart jammed causing elec. start to not work
I have an 84' FXST that was running and starting (when using electric start) as it should until I tried to kick start it. When trying to kick it, the kicker would jam and not return properly. I finally got the kicker to return but now when I try elec. start it clicks and you can hear something struggling to turn.
Any ideas on how to fix this issue?
Old Jun 30, 2024 | 06:34 AM
Baird's Avatar
Baird
1. disconnect battery
2. take trans side cover off and see why kicker misbehaved and repair.
3. When you try electric, did the lights go really dim?
get prepared to remove primary cover , starter and solenoid
Old Jun 30, 2024 | 09:50 AM
DeweyCrowe2's Avatar
DeweyCrowe2
^^^ This.
Old Jun 30, 2024 | 10:41 AM
crb2855's Avatar
crb2855
You could try putting it in gear and rocking it back and forth to see if that frees it up, but even if it does you still need to go in and see what happened.
Kevin Polzer
EVO
Jun 29, 2024 09:38 PM
Scaffido
2014-2024 Touring Models
24
Sep 9, 2014 12:20 PM
Roosterboots
Jan 4, 2012 07:50 PM
