Keihin carburetor
Old Feb 23, 2025 | 06:56 PM
76HDflh's Avatar
76HDflh
Default Keihin carburetor
Trying to rebuild an early model Keihin carburetor for a 1976 FLH . I need some parts. Bracket #2 #15. Also choke lever #41 & choke plate #40. If anyone has an early Keihin collecting dust and would be interested in getting rid of it I would be interested. I hope it’s okay to post this here.
Old Feb 24, 2025 | 07:58 AM
Racepres's Avatar
Racepres
I might have an old one...will look.. Note that #2 I believe, is just a piece of bent metal as a support for the cable sheath.. Choke operate without it..tho rod (rigid type) need to be bent just so.. #15 tougher to locate.. I'm semi sure the choke plate is same on all Ka-Sneeze..I have one.. lever?? again, tougher to find an Early one...Looking.
Might I suggest a Replacement Carb while you are seeking Period Parts..They used to give em away..Swap meets May still have em...they do Here.
Old Feb 24, 2025 | 08:28 AM
Russrust's Avatar
Russrust
hey George it's Russ-- I don't have any parts --if you want I can check with my friends shop in Tuckerton or there's a guy in Ocean Gate who has a lot of parts
Old Feb 24, 2025 | 08:37 AM
76HDflh's Avatar
76HDflh
Thanks Racepres, I checked a couple independent shops and they said the same, going to be a hard item to find, especially the brackets. They also asked why am I trying to find it, there are better options out there. They liked the S&S for shovels, but said would probably be about $700 for carburetor, manifold, air cleaner. This is a fun project, just trying to make it as original as possible. Oley, PA is coming up in April will make a trip and search the vendors.
Old Feb 24, 2025 | 08:41 AM
76HDflh's Avatar
76HDflh
Hi Russ, thanks that sounds terrific. Might take a ride to Nick’s cycle in Williamstown. His place is like a salvage yard for motorcycles.
Old Feb 24, 2025 | 08:42 AM
kink04fxd's Avatar
kink04fxd
Ebay.
Old Feb 24, 2025 | 08:49 AM
76HDflh's Avatar
76HDflh
I checked eBay, they have reconditioned ones for $150 or more or later model Keihin’s that are not date correct. Even the ones that are dated correctly are missing the brackets. I have a good rebuilt carburetor body, I’m just missing the choke lever, plate and brackets.
Old Feb 24, 2025 | 11:11 AM
t150vej's Avatar
t150vej
It's been a few months but I have seen numerous plastic choke parts NOS. You have to be diligent and persistent in your searches.
The parts you seek are always the ones missing, broken, what have you. I've never understood that...
Old Feb 24, 2025 | 12:17 PM
1981 suprglide's Avatar
1981 suprglide
are we talking Keihn butterfly? I'll check may have one
Old Feb 24, 2025 | 01:12 PM
klammer76's Avatar
klammer76
Check with JT's Cycles in Cobleskill, NY. JT has some good stuff in the basement. Hit & miss.
