Cases and crank I.D ???
Old Mar 19, 2025 | 07:44 PM
tinymike66's Avatar
tinymike66
Default Cases and crank I.D ???
I have a set of cases
Numbers inside are
Right side 24563-70B
Left side 24541-70B
Crank
Flywheels are
28934-78
28922-78
Old Mar 19, 2025 | 08:14 PM
hellonewman's Avatar
hellonewman
Why not post some pics?
Old Mar 22, 2025 | 03:30 AM
Fossy-76's Avatar
Fossy-76
1st Gear
Second pictures.
As for the cases, those numbers are castnumbers for 70s shovelheads. What you want to look for are stamped numbers, vin is located on the right front side. Or else there should be numbers inside the right side case beside the cambearing, and outside and underneath on the left case.
Old Mar 23, 2025 | 06:27 PM
Racepres's Avatar
Racepres
Yes..as said, the Numbers on right case front of Tappet block, tell all one should Need!!
Old Mar 25, 2025 | 02:00 PM
tinymike66's Avatar
tinymike66
Yes, thing is , I believe this engine was a put together
I assumed I bought a 1982 year
Then I tore it apart and found an EV3 cam and I suspect the crank is also different than the one originally in there
I'll check the vin tonight and see
Morel00
Mar 10, 2019 06:24 PM
TexasD
Jun 2, 2018 02:59 PM
joust124
Jun 5, 2013 08:55 PM
