frames
Old Aug 19, 2025 | 05:26 PM
john lee's Avatar
john lee
Default frames
are the big twin cone fx frames the same as the flh regarding different weld on brackets ? thanks
Old Aug 19, 2025 | 05:44 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Could you be a bit more vague?
Old Aug 19, 2025 | 06:07 PM
john lee's Avatar
john lee
rear peg and running board mounts also horn mount
Old Aug 19, 2025 | 06:17 PM
Racepres's Avatar
Racepres
Year dependent.. Early frames?? No Difference..later on?? .. No right tabs for forwards..no footboard Tab, horn mount is Only on downtube of Later FX frames...etc... Again Early, (how early..gotta study) all the very same.. certainly thru 1975...which is where I end until 1984...the end!!
Old Aug 19, 2025 | 06:56 PM
panz4ever's Avatar
panz4ever
As Racepres stated, thru 1975 models for sure (owned a stock 75 FXE at one time). Around 77/78 MoCo started diverging. My 78 FXE, from the factory, had the right footboard/ floorboard mount cut off. And the left primary outer cover no longer had the footboard mount on it. Can't speak to the FXS models tho. I think late 70s? HD stared to give the FX series their own frame treatment. Hopefully someone with a later lead can chime in.
Old Aug 19, 2025 | 08:15 PM
Ken45's Avatar
Ken45
My '81 FXS has the right 2 bolt mount at the front of the frame. If you have more questions show me what you want to know and I will look. The only FL I had was a new one so I know nothing about a shovel one.
Old Aug 19, 2025 | 09:35 PM
deathrowdave's Avatar
deathrowdave
My 75 same FX and FL . My 84 FXWG and FL lots of differences , must is no where for foot boards on 84 , no way to use OEM parts to swap on boards , horn is on down tube , rear MC and brake pedal is totally different .
Old Aug 19, 2025 | 10:43 PM
AJSHOVEL's Avatar
AJSHOVEL
Yep. OP needs to get year specific and also state what he's trying to do or looking for.
You can add footboards and controls to an FX frame W/O the RH frame tab or the LH primary tab by using early FL Softtail parts.
Old Aug 20, 2025 | 12:16 AM
john lee's Avatar
john lee
late70s -84
Old Aug 20, 2025 | 12:24 AM
john lee's Avatar
john lee
i was talking to a hd mech who worked for a dealership and he saw the dealer stamping a heap of vin plates FLH and attaching them to fx frames as well as FLH frames in the 70s
