Shovelhead oil return question
Old Nov 16, 2025 | 10:44 AM
chizzler's Avatar
chizzler
Originally Posted by Racepres
A Ducati, as well as Miriad Imports, circulate the Same oil thru-out.. engine and Trans/clutch... Harleys decidedly Do Not... the small bit of oil removed (cycled out) from the chaincase is sent directly to Return...thru Filter...making the return side of the oil pump the Only place that sees that oil..so...Cycled thru the engine is a Stretch at Minimum!!
Again... Trouble Free for ??? Since New!!!
Sorry, you're not going to convince me to keep it. On top of what I already said, mine was missing the starter seal at the top of the primary. That case is supposed to be sealed and hold vacuum. If it doesn't, on top of the clutch fibers and metal particles, it's also sucking in unfiltered air and dust from outside the primary area. And I'm pretty sure that return is there for added lubrication of the cam case, which is why I asked my original question.
Old Nov 17, 2025 | 06:40 AM
Architect's Avatar
Architect
If you want to isolate your primary, follow the diagram that Panz posted, tried and true method.
Old Nov 18, 2025 | 10:29 AM
panz4ever's Avatar
panz4ever
chizzeler, not sure if you are trying to invent a better mousetrap, but as Racepres stated that diagram is tried, true and tested. There is a reason it is still posted and used 25 years later.
Old Nov 18, 2025 | 05:30 PM
chizzler's Avatar
chizzler
Not sure by who yet. No one has come and said they've put ten of thousands of miles on their bike without issue with it bypassed like that. That's kinda what I was hoping for. I like the cartoons and stuff, but the only thing that diagram guarantees is that no oil from the engine will drip on the primary chain. Racepres said I should leave it alone, actually. Not sure what's going on here. Did I accidentally question the orthodoxy on this or something? I still don't think my question is unreasonable, but I'll change it.
Has anyone here put tens of thousands of miles on their Shovelhead without issue with the primary oiler bypassed like that diagram, and the return to the cam case plugged?
My bike won't be going back together for a month or two, so I have time for an answer. If I don't get one I'll probably run the hose from the tank to the cam case and see if it sucks all the oil out of the tank and barfs it all over my garage. Lol
Old Nov 18, 2025 | 05:35 PM
chizzler's Avatar
chizzler
Must be an area cultural thing, with rare exceptions with gents like Panz who are factory correct aficionado’s I’ve seen few factory stock oiling systems on bikes that get high miles as daily riders since the 70’s. Can’t remember the last stock shovel oil system been on my lift. As with many on the designs the old girls came out with, while it works it isn’t always the best option for the machine, it was the **** they wouldn’t have done away with it with the evo and onward.
Sorry, I take it back. Twizted seems to say here that he's seen a bunch of bikes from way back that were bypassed and were fine. Is that correct?
Old Nov 18, 2025 | 05:53 PM
RHPAW's Avatar
RHPAW
I have. About 50,000 miles since I did it. No issues.
Old Nov 18, 2025 | 06:34 PM
chizzler's Avatar
chizzler
Perfect. Thank you. I'd like to put some miles on my bike so I appreciate the reply.
Old Nov 18, 2025 | 06:39 PM
Joe12RK's Avatar
Joe12RK
Only 9000, and I can't say it wouldn't have been just as good the stock way, because I wash the gunk out of the oil tank every other oil change like you're supposed to.
Old Nov 18, 2025 | 06:43 PM
chizzler's Avatar
chizzler
Yeah, that definitely wasn't done on my bike. It needs a good de-gunking.
Old Nov 20, 2025 | 07:53 PM
TwiZted Biker's Avatar
TwiZted Biker
Lol my signature shovel and I are 43 years and well over 300K miles in various builds and configurations together and every one of those miles was with the simplified primary isolated oiling setup due to belt primaries. Stock chain primary didn't make it 6 months as I kept knocking holes in the primary cover riding it like I was mad at it.
It works, it works as well as the stock oiling system without the drawbacks the factory system had. 3 plus generations of shovels riders were doing it long before the internet came along to confuse everybody over simple things like this. These engines are very much uncomplicated and extremely forgiving to a lot the recent generation motors would chew themselves to junk over.
The bikes puking it's the check ball seat in the pump body, they can and do get a hairline crack at times, something's not timed right in the cam case, or you got massive blowby going on and then it'd be blowing oil out seals and the pushrod tubes what little it will run. Really isn't much else to it.
