'81 pushrod installation trouble
Old May 9, 2026 | 09:43 AM
Robtattoo's Avatar
Robtattoo
Default '81 pushrod installation trouble
My engine runs *chef's kiss* perfectly & is 100% oil tight, however, it was in need of a little tidying & paint. I pulled the pushrod tubes & rods without removing the rocker boxes (and I reeeally don't want to have to....) pulled the lifter blocks out & got everything cleaned, polished & mostly put back together.
I absolutely CANNOT get the rear cylinder, intake pushrod back in. It was a tight fit getting it out & I've already stabbed a screwdriver through my thumb trying to get the bastard back onto the tappet. Oh, it's hydraulic lifters, by the way. The other 3 drop in, no problem, this one just doesn't seem to have enough compression in the spring to let the pushrod ball in. The lifters have been out of the motor (and laid on their sides, if it makes a difference) for 5 days, so I can't imagine there's any pressure left. The outer piston (?) is fully seated & the cam is absolutely at the lowest point (I'm looking at it through the lifter block hole for the front cylinder) but the little, sprung, inner piston just will not compress far enough.
Is there a trick I'm missing or am I really going to have to pull the frigging rockers? 🫩
Old May 9, 2026 | 10:03 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What are you working on, model and year?
What pushrods are you using?
Old May 9, 2026 | 10:09 AM
Robtattoo's Avatar
Robtattoo
Sorry. '81 FXWG. I'm not sure if the pushrods are original. They're adjustable with a split locking nut.
Old May 9, 2026 | 11:27 AM
panz4ever's Avatar
panz4ever
Had an 84 FLH and the rear intake was always a buggar to get back in unless it was completely dry.
Old May 9, 2026 | 11:47 AM
Robtattoo's Avatar
Robtattoo
The key word: "completely"
I just had a really good search around & learned about the 'paperclip through the bottom of the piston' trick. Less than a drip of oil came out, but it was enough that it was still holding pressure!
I got it totally dry & it all popped together perfectly!
I should've searched before asking, I guess 😁
Old May 9, 2026 | 11:52 AM
pgreer's Avatar
pgreer
delete
Old May 9, 2026 | 11:56 AM
Joe12RK's Avatar
Joe12RK
@pgreer are you thinking of EVO pushrods? I thought shovelheads were all the same. I could be wrong though.
Old May 9, 2026 | 12:10 PM
pgreer's Avatar
pgreer
@Joe12RK I deleted my post since he solved the problem.
So I checked the pushrod part and there is only one part number listed for 66-* shovels. So they must all be the same length.
Paul
Old May 10, 2026 | 11:51 AM
panz4ever's Avatar
panz4ever
Thumbs up
Glad you got it figured out.
Old May 10, 2026 | 04:53 PM
john lee's Avatar
john lee
am i correct in saying when adjusting the pushrods you adjust them so they spin freely with no up and down movement
