Wheel Hubs
Old Dec 19, 2007 | 10:36 AM
panz4ever's Avatar
panz4ever
Default Wheel Hubs
I have a hub for a 76 FLH that I am rebuilding. The manual talks about checking bearing end play when wheel axle is tightened. My question is this....is there a way to check proper end play without mounting the wheel on the bike? This is my first shovel; my only other bikes are pans with the star hubs andendplaycan be checked without mounting the wheel to the bike. Just trying to avoid needless time if it can be done another way.
Old Dec 19, 2007 | 02:54 PM
crampfan's Avatar
crampfan
Default RE: Wheel Hubs
I have a set of spacers I made up. cleanthe wheel bearings of all grease. install them in the hub, using the spacer and shims. install the axle through the hub, using what ever spacers you can find (sockets, pipe, ect.) to get the nut to tighten. use a dial ind. add shims as needed ( instead of buying diff. spacers, I buy the longest andtrim iton a lathe)
Old Dec 19, 2007 | 02:57 PM
panz4ever's Avatar
panz4ever
damn...way easier and less time! Thanks, Dave
HD-Heaven
Aug 22, 2018 07:56 AM
z54071
Mar 14, 2016 07:27 PM
bobgv
Apr 24, 2015 04:01 PM
cHarley
Nov 22, 2007 04:33 PM
JOEY5632187
Jun 23, 2006 06:04 PM
