77 fxe start relay mounting
Old May 11, 2008 | 08:52 AM
beau's Avatar
beau
Default 77 fxe start relay mounting
Where is the stock mounting location for the original big round starter relay (the one that looks like a solenoid)? Can this be replaced with a smaller more modern starter relay?
thanks in advance
-b
Old May 11, 2008 | 09:00 AM
Rodney's Avatar
Rodney
Default RE: 77 fxe start relay mounting
I've seen most starter relays mounted on the bottom side of the battery tray
No you need the large starter relay to accommodate the battery cables and the smaller bosh type relay to excite the larger relay. {this is how my 68 is set up} and my buddies 80 fxwg also has both relays with the bosh type mounted on the back side of his battery tray if I recall.
Old May 11, 2008 | 05:48 PM
captchaz's Avatar
captchaz
Hi Beau,
On my 79 the relay is the big one and is under the battery tray also. Make sure your ground is good or you will get nothing when you hit the button. This gave me fits a couple of years ago.
Old May 11, 2008 | 06:00 PM
ARBY's Avatar
ARBY
Yep, it definitely mounts under the battery tray. However on my '77,I have forsaken the starter realy and all the grief associated with it when I moved my ignition switch and starter button.I kept either cracking the relay mount or burning out the realy itself. So,I wired directly from the battery (through a circuit breaker of course)into a high amp momentary button - NAPA number SW10 and have been trouble free for the last five or so years. Works for me.
Old May 11, 2008 | 06:07 PM
ARBY's Avatar
ARBY
By the way. If you want to replace the relay with another one, take yer old oneto any car parts store and pick up a relay for any early model Ford truck relay. It's sturdier and cheaper than one from Taiwan Ted, Custom Chromeor the Harley stealership.
mbierbac
Nov 2, 2012 09:41 PM
parichar
Oct 1, 2011 02:33 PM
radio915
20
Apr 15, 2011 08:58 PM
vetto
Feb 26, 2010 05:29 PM
dirtyboy
Ironhead
16
Jun 7, 2009 05:45 AM
