need help from all you pros
i can just buy Allen bolts this size
doesn't matter if there threaded all the way up as long as there grade 8
Thats why the 12 points are used, so one can turn them a little at a time, especially when re-torquing once the engine is all together getting behind the carburetor and the one on the left {rear head}
http://buy1.snapon.com/catalog/item....e&tool=all
this is what i used, not a problem torque'n the head bolts.
if the link dont work here is the stock # FRDH181
"FxLowrider"
Thanks for that info and link on the Torque Adaptor, 9/16", 12-Point, it looks like a winner !!
Attached:
Swivel headtorque see if you can beg, borrow or steal (give it back
this really takes the hard work out of it, it belongs to my best friend the one in the picture, been a GM wrench for a long time. cj
[IMG]local://upfiles/16813/75F61FF5012B4A59ADC1E40089BB59F1.jpg[/IMG]
https://www.emaxaction.com/index.asp...stom&ID=25
Thanks,
Years ago, I was told by one of the best Harley machinist/mechanics I have ever known that if ya can't get a torque wrench on the head bolts for a Shovelhead, pull 'em up to "blue torque." "Blue torque" as many of you know is achieved by pulling on the wrench until you are blue in the face. His lesson really was that you get the bolts as evenly torqued as possible at a good tight tension. Now there are some big boys out there that are gonna rip the inserts right out of the heads pulling on a wrench as hard as they can so it ain't a good idea to tell them that. It is a learned skill and it can have disasterous results until you "get it."
The fact is, most torque wrenches won't fit to get directly on the bolt heads so guys have had to improvise...
what did i use?
what i always used before
a 9/16 12 point wrench
never had a problem before
im pretty sure if i used the steel gaskets this would have never happened
it was the rear portion of rear cylinder
gotta love it........lol
[IMG]local://upfiles/48181/10BDEF34E11D4265858FFE9C58BD3666.jpg[/IMG]
[IMG]local://upfiles/48181/1DDBD5CF32794D6F972EF1645FF77DE8.jpg[/IMG]
I have tried to use some poorly made gaskets in the past where the alignment was so far off they couldn't be used.
IF the gasket material bunches up from miss alignment this will not allow the head to mate completely flat with the barrel allowing gases to leak past causing the gasket to fail.
Using any gasket made any more I will compare and blue print each gasket for fit.
Yes use a torque wrench when ever possible but as megawatt says its not always doable and one must be careful when adding any extensions, adapters or even not being completely square on the bolt will give you a false reading and may cause more problems. The threads also need to be lubricated for an accurate reading.
Torque wrenches also need to be taken care of and re calibrated any time your in doubt of the readings.
Theirs a lot to take in to consideration when tightening a bolt:
[quote]"Donât go by what is in the âbookâ (repair manuals) for clamping," Brown explains. "Who knows where those torque specs came from?" If youâre using specialty fasteners that have much higher strength than OE fasteners, then these torque specs will have no relevance. "These specs could have been lifted from an OEM bulletin somewhere," warns Brown. "And youâll find out pretty quickly then, if you snap a bolt or stud, that it was wrong." Most specialty bolt manufacturers provide detailed instructions with their kits explaining how to install, and torque their bolts, as well as what type of lubrication to use. Some even include charts showing how much clamping load to use. Very few engine builders know how much clamping load they need, says Brown. In many cases, theyâll measure the clamp load by using torque values, and this, in turn, creates some confusion. âSay you torque a 3/16Ë bolt; you can torque it to 100 ft.lbs. if you donât put any lubricant on it because it generates so much friction. But, if you put a dab of moly lube on the threads and under the head, you may only be able to torque it to 30 ft.lbs.," Brown explains. Some of the confusion surrounding torque and preload comes from not knowing the difference between them. Torque is just the twisting force. Itâs an index number and does not equal load. You also have to compensate for the friction coefficient of the oil. Therefore, torque values should be accompanied by the specified lubricant for the most consistent results. Carroll Smith agrees that friction plays a vital role in achieving proper stretch and clamp load. And if you use a different lubricant than the one provided by the bolt manufacturer, Smith says, "good luck." Itâs critical to use the correct lube because it was designed for the specific bolt and application in many cases, especially in high performance applications. Many high performance bolt manufacturers include the lube with the bolt kit when you buy them. "Obviously, the more slippery the lube is, for the same amount of torque youâll stretch the bolt further, and vice versa," says Smith. "Proper lubrication of head bolts doesnât really matter as much in a vintage 289 Ford â but if youâre assembling a true high performance engine, youâve got some real pressure inside of those cylinders. "If youâre running a 13:1 compression engine at 9,000 rpms, youâre trying to lift those heads right out of there. If youâre running a 9:1 engine at 4,000 rpms, you can practica
