cases leaking
Old May 31, 2008 | 03:01 AM
hddee's Avatar
hddee
Default cases leaking
can somebody please help:my cases are leaking at the front of motor does anybody have a solution to stop the leak without pulling the motor out asi have got the bike in show room condition and dont feel like stripping it down for this :the motor has been rebuilt for a couple of years now and was done professionly: help
Old May 31, 2008 | 06:53 AM
AlCherry's Avatar
AlCherry
Default RE: cases leaking
Sorry to tell you, but you have to split the cases to reseal them. There is no other solution. You can do all of the work youself. You DO NOT have to pull the cam chest and oil pump. The cases can be split from the left, resealedand reset. Did it more than once myself. Just take your time and do it right.
Old May 31, 2008 | 07:50 AM
sqdealgeorge's Avatar
sqdealgeorge
I've had some success by taking the whole bike and laying it on its side (no gas in tank and a base of car tires) Scrub the leak area with brake clean and a brush Sand area around leak The bike has to stay in this position for 2 days plus to make sure oil has stopped leaking thru Then I used a good 2 part epoxy Let it dry 24 hrs plus I did an old XL this way lasted 2 years plus
Old May 31, 2008 | 08:11 AM
Rodney's Avatar
Rodney
Are you sure it's leaking where the cases join or could it be a barrel gasket seeping down?
have you put a wrench in all bolts lately?
bparsel
EVO
27
May 6, 2021 06:01 AM
Tony_N
EVO
27
Jan 22, 2014 10:39 AM
patharley
Jun 3, 2012 09:03 PM
87HDFXSTC
EVO
11
Oct 16, 2009 05:26 PM
wbogley
Shovelhead
Jul 28, 2008 01:00 AM
