got a leak (oil)
Old Sep 28, 2008 | 01:59 PM
IlDuce's Avatar
IlDuce
Default got a leak (oil)
Ok, I was taking a look at my engine today (80 inch shovel) and i noticed the 4 rocker box screws are leaking... What is the best way to remove them to replace the O-ring? I was told to becareful because i dont want to turn the shaft that the cap screw is screwed into.. can someone help me out
Old Sep 28, 2008 | 03:30 PM
megawatt's Avatar
megawatt
Make sure the nut on the other end of the rocker shaft (left side of the engine) is tight, then just unscrew the rocker arm shaft screw. The only thing that keeps the shafts from turning while you take the right side screws loose are the nuts holding the shafts against the inside of the rocker boxes on the left side.
Old Sep 28, 2008 | 03:58 PM
IlDuce's Avatar
IlDuce
cool thanks
1984 flhs
Shovelhead
24
Oct 30, 2018 09:00 PM
TPS79
Shovelhead
Aug 13, 2014 06:47 PM
FL54
Shovelhead
Jul 16, 2014 05:47 PM
pesnemesis
Shovelhead
May 6, 2014 08:25 AM
shovelhead FXEF
Shovelhead
Aug 7, 2012 09:25 PM
