a problem with shocks/studs fitting
Old Jan 22, 2009 | 06:25 PM
jarrette's Avatar
jarrette
Default a problem with shocks/studs fitting
I bought some shocks for my '66 FLH from Debrix.com, I also bought a full set of new mounting hardware from them. The original shocks have two rubber bushings for each eye. The shocks I bought actually have a "built-in" rubber fitting so there is no room for the bushings that came with the hardware....I would be fine with that, except the mounting bolts DONT FIT into the built in fittings! Anyone have any experience with this? Did they send me the wrong shocks?
this is the item I bought (which I believe is just the V-Twin aftermarket set)...
Item Title: Full Covered Shocks Set for 1958-1972 Harley FL-FLH
Quantity: 1
SKU#: 54-0111
here's a pic to better describe what the hell I'm talking about...
Old Jan 22, 2009 | 09:38 PM
shiftless's Avatar
shiftless
I have had to add bushings or remove them, and go to the hardware to buy the ones that fit. I have bought shocks that came with extra bushings. (?multifit) Not sure its BTB but... If you knock that bushing out, thats in the new shock, will your studs fit? If that works I'd run with that. JM2c
Old Jan 23, 2009 | 07:02 AM
sqdealgeorge's Avatar
sqdealgeorge
The shock stud kits are different for 1965/66 FLH Maybe they sent you the wrong set
Old Jan 23, 2009 | 02:03 PM
jarrette's Avatar
jarrette
the old studs have the same diameter as the new studs. Neither the old or the new studs fit in that new hole. The rubber fittings have a metal center and are really in there good. If I got them out, there's no going back... Should I just dig them out then?
Old Jan 23, 2009 | 06:20 PM
JohnB445's Avatar
JohnB445
I would not dig the center out of the new shock. You don't need the rubber
pieces with the new shocks. I have put shocks on, and the studs did not fit.
The bolts, were out of round. Try to line up the steel shafts, that were inside
the old shocks, with the new bolts. See if the size is close. I had to go over
the round part of the studs with emery cloth. A few thousands on an inch
make a big difference. A little WD-40 and the studs went through with a
LITTLE (repeat little) tap with a plastic hammer. I hope this helps.
I have watched your posts since you started. Looks like your are coming
along pretty good.
Old Jan 24, 2009 | 08:47 AM
jarrette's Avatar
jarrette
thanks for the advice, John. That's the thing, though, the old shocks didn't have a steel shaft, just the two rubber pieces...
Old Jan 24, 2009 | 09:44 PM
shiftless's Avatar
shiftless
Is that spacer in the new shock the same size as the stud your putting in there? If it is, knock that bitch out of there and put them shocks on. If the hole in the rubber without that spacer is to big, you may have to go to the hardware, get one of them spacers to fit your stud and drill the rubber to fit it. Use a vice to replace the spacers, if needed. JM2c
Old Jan 26, 2009 | 10:58 AM
jarrette's Avatar
jarrette
yeah it sure is (the same size). I may give that a try.
Old Jan 27, 2009 | 10:14 AM
JohnB445's Avatar
JohnB445
Default pictures of shocks
I hope these come through
Attached Thumbnails a problem with shocks/studs fitting-66-shocks.jpg   a problem with shocks/studs fitting-shock-pics-001.jpg   a problem with shocks/studs fitting-shock-pics-002.jpg   a problem with shocks/studs fitting-shock-pics-003.jpg   a problem with shocks/studs fitting-shock-pics-004.jpg
Old Feb 5, 2009 | 09:30 AM
jarrette's Avatar
jarrette
hey, thanks John. Yeah, it looks like from the pics that your shock eyes are the same as mine. There are no built in inserts/sleeves. The hardware and rubber are separate hardware, which makes sense. The company emailed me a UPS shipping label so I just sent them back and they say they are going to send me replacement shocks, so we'll see what they send me.
I'll post a pic of what they send.
