trani
Old Apr 15, 2009 | 07:06 PM
mudmill's Avatar
mudmill
Stage I
Default trani
Hope this doesnt sound 2 stupid. draind my primary n i got oil, looked in the fill hole 4 the gear box n it looks like gear lube, trani. fluid, red line,something im not sure? So, i think my primary is closed off n the lubes, im guessing r correct?
Old Apr 15, 2009 | 10:37 PM
KT77's Avatar
KT77
First off what bike do you have?
The trans and primary are seperate. If your bike is a shovel and has a dry system, Your engine oil will feed the primary, If you have a converted wet system, The hoses from your oil pump will be gone and the primary will be sealed and filled with usually something that will look like trans fluid. 4 speed trans gets 22 to 24 ounces of fluid, primary depends on what it is. converted systems get 8 to 13 ounces depending on who you talk to and newer systems get a whole quart. You'll have to figure out what you have there.
jphillips
Sep 3, 2014 10:03 AM
P51Driver
May 8, 2013 04:54 PM
tomtek
Oct 19, 2010 06:36 PM
cwickgo9
Apr 27, 2008 09:43 PM
OneBlackFly
Oil Archive (no new posts)
Apr 3, 2006 12:59 AM
