Electric start problem
Old Aug 21, 2009 | 08:34 PM
Snowturtle's Avatar
Snowturtle
6th Gear
Default Electric start problem
I just replaced the starter relay and the solenoid on my 79 FXE because my electric start didn't work. For the first few times, it worked great, but now all of a sudden, it sticks and won't quit cranking until I disconnect the battery! I lost spark at the same time this problem started so it just cranks and won't start. I took out the starter shaft and checked all gears for wear and everything seems fine. For some reason, the new solenoid won't disengage until power is cut off. Turning off the key doesn't do it, it has to be the battery. What happened?????
Also, where did my spark go? No spark at the points (I dumped the electronic ignition years ago) or plugs and when I test the coil the way my shop manual describes, it has 12 volts coming out of it when not running.
Thanks for any ideas, I'm stumped by both electric problems.
Old Aug 21, 2009 | 11:25 PM
FilthyLucre's Avatar
FilthyLucre
The sticking solenoid is usually caused by a weak battery. You may have to disassemble the solenoid and reverse the contact plate if it is heavily pitted from sticking. If you are sure your coil is good, change the condensor. A weak or bad condensor will cause the no spark condition.
Old Aug 22, 2009 | 07:35 AM
sqdealgeorge's Avatar
sqdealgeorge
I'll second Filthy on that responce
Old Aug 22, 2009 | 08:48 AM
AlCherry's Avatar
AlCherry
Kick start RULES! Besides, a lot of yups always ask the question: "Whats that peddle on the side of the bike for?"
Old Aug 22, 2009 | 07:27 PM
JohnB445's Avatar
JohnB445
You may want to check your wires. This summer my
my electric start, started turning over by itself. It
would not quit. I had to pull the battery out to get it to stop.
Problem turned out to be, 2 wires had worn through
the insulation. It easy to check the wires before
moving on to harder things. Hope your problem turns
out to be an easy fix.
1980 wideglide
Old Aug 24, 2009 | 07:48 AM
Snowturtle's Avatar
Snowturtle
6th Gear
Default Thanks
The solenoid is new but that does not guarantee that there is nothing wrong with it. The battery is also new and fully charged. I got it running somewhere between re-recharging the battery, cleaning all electric connections, resetting the points, and bypassing a tempermental on/off switch on the handlebars. The starter still sticks but will disengage when I kick the solenoid multiple times with my boot heel. I will mess with how the solenoid is mounted or order another new one.
The electric start has been unreliable for many years. I only started messing with it because the kickstarter jammed when it backfired and broke a tooth off the gear. Fixing that is definitely my next priority! I always preferred that anyway because none of the penny loafer crowd on their brand new Harleys here in Aspen would know what to do with it. Heck, they can't even turn around without going around the block, much less start their machines without a button!
Thanks for the replies.
Old Aug 24, 2009 | 12:51 PM
FilthyLucre
Its mentioned in the manual but I'll restate it here. When you install the new or reassemble the Starter Drive Gear (bendix gear) on the starter shaft DO NOT use grease or oil on the the shaft where the gear rides or it will stick.
Old Aug 24, 2009 | 05:53 PM
sqdealgeorge
What about never seize ?
Old Aug 24, 2009 | 07:40 PM
FilthyLucre
The book says no lubrication. I made the mistake of putting a small amount of light grease on it once and sure enough it stuck. Neverseize is a graphite grease. It gets a little lub from the oil flying around in the primary and evidently thats enough.
surgeon general
Sep 23, 2014 12:46 PM
Scubamike
Oct 13, 2011 10:09 PM
MPD071
Apr 4, 2011 11:24 AM
redinthehead
Panhead
Aug 13, 2007 08:25 AM
ironorange
Sep 18, 2006 01:38 AM
